Status
Not open for further replies.
dysan
Dis-Member
Williamstown, N.J.
Another best
The following vehicle information:
- Cubic inch displacement (CID) of engine - 302
- Type of transmission (by model number) - 3650
- Size and Manufacturer of power adder, or N/A - E-Force 2.3L
- Pounds of Boost, of N2O shot (or both if applicable) - 11psi
- Rear Gear ratio - 4.10
- Make and type of tire - M&H 275/50/17 DR
Previous time is within 2% so no need to put up 2 slips on this post.
Car 04
1.627 60'
4.772 330'
7.315 1/8 @ 96.26 mph
9.501 1000'
11.342 1/4 @ 123.09 mph
DraggnRoush
Jimi Hendrix Blues
NYC
NICE ONE dysan... so please describe your launching & shifting techniques (with the WOTbox I assume)..?
dysan
Dis-Member
Williamstown, N.J.
Thanks! I have my wotbox at 3000 rpms for the 2-step and I pretty much just slip the clutch off the line. I'll post up a video from in the car on Sunday and you can hear how I launch. I don't know if my launch rpm's will work the same for you since you're using a centri blower and I'm using a TVS so I believe I get more torque as soon as I let the clutch out.
As far as shifting, I really just kind-of feel the car out as I'm going. Sometimes I'm shifting out of first just shy of 5k rpms and the rest are usually right around 6k rpms. Once again, since you're using a centri blower you'll want your shifts as high as you can at the edge of your power band since you make your peak power higher up, when mine starts dying off shy of 6k.
This video was from Sunday when I ran my 11.42, I haven't had a chance to upload last night's 11.34 run yet. I think my car has more in it since I don't shift very fast in an effort to keep my 118k mile transmission from grenading on me.
EDIT: the youtube embed doesn't seem to be working so here's the link...
http://www.youtube.com/watch?v=78d4wU9TsnU
killr3v
Hector G.
Katy, TX
Third time at the track ever. First time running the ET Streets. Spun a little on my 2 best e.t. passes since I didn't warm the tires enough. DA was around 1300', 84*, 95-100% humidity. Only got 4 runs in and the other two were 13.30s. There are definitely some 12s in her. Just need some more seat time.
Mods:
BBK CAI, BBK t/b, UDP, CMDP, o/r xpipe, magnapacks, 93 tune, fsb delete, short shifter, 2step.
4.6
TR 3650
N/A
Stock 3.55
ET Streets
DraggnRoush
Jimi Hendrix Blues
NYC
OK I just viewed the video... and you're quite right, your car is much more "torquey" - as I listen to your shift points I hear they're lower RPMs than mine. It sounds like you're hooking pretty damned well off the line I don't hear tire spin... overall it looks like you're doing everything well & make it look easy - GREAT JOB bro... thanks for sharing!
BLKS197
Formerly TAJoerg
Buffalo, New York
- Cubic inch displacement (CID) of engine - 281
- Size and Manufacturer of power adder, or N/A - D1SC Procharger
- Pounds of Boost, of N2O shot (or both if applicable) - 10psi
- Rear Gear ratio - 3.55
- Make and type of tire - MT ET Street Radials
Car 74
1.766 60'
5.020 330'
7.719 1/8 @ 96.26 mph
10.024 1000'
11.998 1/4 @ 114.38 mph
Waiting on my friend to host the video, also had a best trap speed of 115.69 on a 12.32 pass
In case my embedding sucks: http://www.youtube.com/watch?v=fOYV3bvKs38
Noclutch
Niagara Falls
Nice run Ted. :thumb2:
I got My PB
- Type of transmission (by model number) - 5R55S
- Size and Manufacturer of power adder, or N/A -N/A
- Make and type of tire -Pirelli pzero street
1.966 60'
5.477 330
8.364 1/8
84.69 mph
10.878 1000
12.998 1/4
106.55 mph
Second best of the day was a 13.07 @ 106.2mph
BLKS197
Formerly TAJoerg
Buffalo, New York
I got My PB
1.966 60'
5.477 330
8.364 1/8
84.69 mph
10.878 1000
12.998 1/4
106.55 mph
Thanks man, congrats on your 12's. Get some drag radials and you will be running 12.70s
Boss281
New Windsor, MD
New personal best 12.099 at 110.30. Note this was on ET Streets, not ET Radial. Note the reaction time: I waited for the green to ensure my RPMs were up. I'm not that slow off the tree! Thanks fellas...
GrnBullitt08
Dale Jr
Northwest Indiana
11.11 @ 124 will post slips tomorrow
Good god.....your trap speed is insane......
- Size and Manufacturer of power adder, or N/A - N/A
- Rear Gear ratio - 3.73
- Make and type of tire - Goodyear F1s
Best of the day for me was 13.4840 @ 99.16 (2.0290 60'), Will post slip tomorrow.
Status
