Status
Not open for further replies.
psfracer
billy badass
Valencia, CA
Good job breaking into the 12s. Now, what about 11s? You have 6 months.
I wonder where all of the 4V cars are at? No 4Vs are posting their times in here???:stir:
GrnBullitt08
Dale Jr
Northwest Indiana
Went to the test and tune tonight and set a new personal best time.
First pass I went a 13.079 @ 108.01 w/1.927 60' Second pass I went a 12.978 @ 106.16 w/1.866 60' Pretty pleased that I finally broke into the 12's a little unhappy about the consistency though ! Hot lapped a few more times for some 13.3xx's . In a week or so I plan to add the new 127200 Cams, and see what kind of improvements they give me, then get my new Pype's Long tubes and Torque converter in place.
Nice job on the 12s....Im going for them as well the 19th.
brett2008
glensfalls ny
Those are the kinda times i wanna run nxt yr...
ChevyKiller
Preferred Internet Drink
Can we upgrade the photos on the ranking list - they are in the wrong order...:hi:
Also, my info is correct except I have a TH400 trans and not a 4r70
luillo
Fort Walton Beach, Florida
Finally some decent numbers to post in these thread and more to come: 12.29 best follow by 12.34 and then 12.27 again
Cubic inch displacement (CID) of engine: Stock 302 cid
Type of transmission (by model number): not sure i think the 2011 Mustang GT Manual are something like Getrag MT82
N/A- No Tune, No CAI completely N/A
Rear Gear ratio: 3.73
Make and type of tire: Mickey Thompson ET Street
These is the best ET and 60 ft that i could get before the car started messing around with the clutch pedal laying down in the floor after launching over 6,000 rpm. But i will try next time with BBR Tune and see if i can break 11s ... YESSSSSSSS..
jodadejss06gt
TEAM DELETE SHIT
Severn MD
Well guys this was my first trip to the track since the turbo install. I've made 4 passes down the track ever and 2 of those were pre turbo. I'm still on street tires and got a lot of wheel spin in first and second. I wasn't sure what to dial in at too bad I didn't go 1 tenth south. Here is the slip! I was in the right lane.
69Mach1-409
South Jersey
The first trip to the track with the Whipple HO kit (among some other new mods).. not bad, but there's ALOT of room for improvement. :beerdrink:
Car 14
- Stock 4.6 (281) motor down to the manifolds
- stock trans 3650
- 3.55 stock rear
- Whipple / FRPP 2.3L HO running 8-9lbs of boost in this heat
- MT 275/40R17 DR's
vnmous1
Gentleman & Scholar
Central Florida
Noob posting up
Greetings and salutations. Let's see if I can follow posting directions better than I create sigs.
First post of back to backs oughta be covered by the "twin slip" from May. Latest time is the single 10.91 attached slip from last week.
Vehicle info:
330 CI
Tremec 6060
Factory Eaton M122 w/Posi port
17.5 lbs boost
4.10
M&H Racemaster Drag Radials
Peaky85
Marion, IN
Back with another new PB
Seems every week that I go to the track these days I return with another new PB ... small decreases, but, a decreasing ET is a good thing !
2007 GT Mods in sig only only addition is Mickey Thompson Drag Radials that I have been running since spring (needs updated on the list). Had a few 13.0xx times and a 12.954 @ 106.58 w/1.871 60'
brett2008
glensfalls ny
1/10th is 1/10th.....
JimC
Got a new personal best today:
1) copy of timeslip--see below (the 1/8 mph is lost because a mud guard came off my car and hit the timing lights on this pass)
2) The following vehicle information:
- Cubic inch displacement (CID) of engine: 245 (4.0L V6)
- Type of transmission (by model number): Automatic 5R55S
- Size and Manufacturer of power adder: Xcharger Xtreme
- Pounds of Boost: 12
- Rear Gear ratio: 3.55
- Make and type of tire: M&H 26x11 15
3) your time also has to be backed up by another time within 2%. See Below
dysan
Dis-Member
Williamstown, N.J.
I'll get my slip up later when i get home but i just knocked off an 11.423 @ 121.01 1.624 60' on some pretty worn m&h's. Didn't even feel that quick.
Going to try for a high 11.3 before they kick me for not having a bar.
dysan
Dis-Member
Williamstown, N.J.
- Cubic inch displacement (CID) of engine - 302
- Type of transmission (by model number) - 3650
- Size and Manufacturer of power adder, or N/A - E-Force 2.3L
- Pounds of Boost, of N2O shot (or both if applicable) - 11
- Rear Gear ratio - 4.10
- Make and type of tire - M&H 275/50/17 DR
Previous time is within 2% so no need to put up 2 slips on this post.
Car 1558
1.624 60'
4.770 330'
7.332 1/8 @ 92.20 mph
9.552 1000'
11.423 1/4 @ 121.01 mph
luillo
My Car Info 2011 Mustang GT:
- Type of transmission (by model number) - Getrag MT82 Manual
- Size and Manufacturer of power adder, or N/A - N/A
- Pounds of Boost, of N2O shot (or both if applicable) - N/A
- Rear Gear ratio - 3.73
- Make and type of tire - M/T ET Street 26X11.5-15
Time is within 2%, Two included.
Car 206
1.56 60'
4.88 330'
7.617 1/8 @ 88.29 mph
9.969 1000'
11.944 1/4 @ 114.59 mph
DA 2213
TGJ
Regina, Saskatchewan, Canada
I should update my best time for 2005 Mustang GT...
I don't have the slips handy, but I have the videos...
13.392 @ 101.65
http://www.youtube.com/user/TGJaws#p/u/6/hQyMMUx-yUE
13.393 @ 102.45
http://www.youtube.com/user/TGJaws#p/u/15/QgNoWZAHx3Q
- Cubic inch displacement (CID) of engine - 281
- Type of transmission (by model number) - Tremac 3650
- Rear Gear ratio - 3.55
- Make and type of tire - M/T ET Street 26X11.5-17
Big50
Vallejo,CA
PB 11.72
What car # are you? 138
- Cubic inch displacement (CID) of engine -- 281 4.6 v8
- Type of transmission (by model number) -- stock manual w/mcleod twin disc
- Size and Manufacturer of power adder -- Saleen 2.3
- Pounds of Boost -- 13
- Rear Gear ratio -- 4.10
- Make and type of tire -- Nitto 555R 305-35-18
Time slips - 11.82 to back up the 11.72 PB
Status
