Help me!!!
Black_Steed
long island
Ok so tonight i was out with the guys. Me and a friend went at it at a green light. I didnt launch hard at all more just rolled it out. I went through the gears hard (first through forth). By the time we let off we were braking hard because our destination was comming up. I start to down shift 4-3 then try 3-2 and it made a strange wine! so i pull in to the parking lot in neutral and notice that the car didn't need me to put the clutch in to put it in to 1st or 2ed and wasent allowing me to put it in any other gear 3-5 or reverse.
So now im parked in a parking lot and me and my friend are looking around (one of my friends is a mechanic) no smoke no leaks no smells... I let the car sit for a few minutes and start it back up. seems to be that the car is stuck in 1st gear even when the shifter is in 2ed or neutral! At this point the shift nob can be put in 1st or 2ed with no clutch and will still not got in to any other gear.
So i drive the car all the way home in first FML. The car is driving great becides the fack it will not go in to any other gear. clutch is grabing fine and no strange noise it just feals fine....
Please any help would be great.
HOLYWD
S197 Junkie
Damn !
That sucks man .
I am auto so..... Can't help too much .
Hawgman
THE fucking bad guy
.....and it made a strange wine!
Wow, really? I'm not much in to wine, but if you can get it to start making a descent whiskey I will buy the car off of ya.
Has the thought occured to anyone to look and see if the shift linkage came loose? If you can cycle the shifter through the gears, don't have to use the clutch, and the car stays in one gear. That would be the first thing I would look for.
I know man i have know idea what to do now. Return the car to stock and bring it to ford?
Why would returning it to stock help you in any way? If something came loose, they aren't going to be able to say it was directly (or indirectly) caused by any of the mods you have listed in your signature. If something broke, and you completely returned it to stock (and yes, I mean removing the UDPs, driveshaft, putting stock gears back in, EVERYTHING) they are most likely going to say it was caused by driver abuse anyway. So personally, I think putting it back to stock would be a complete waste of time.
irishpwr46
Official Site Vandal
NYC
i second the linkage. get underneath and have a poke around
Black_Steed
long island
It wont go into all the gears. I cant get into 3rd, 4th, 5th, or reverse. It pretty much only has a first gear. When the shifter is in neutral it acts like it is in first. And second gear as like first as well.
Big50
Vallejo,CA
Did you read Hawgman's post? everything he said sounds like what you are talking about. Jack up the car and check it out. Our transmissions use remote shifters, it is likely this is the cause. Could be a simple fix.
Chilliwack 42
Chilliwack, BC
I think you missed what they are trying to tell you. Your Clutch still works and you can still drive, but it is stuck in first gear. Get under your car and check the shifter linkage. Atleast then you'll know it's not that or a simple fix before you take it to a dealer or another shop.
Black_Steed
long island
Alright sounds good guys. I will take a look at it the next day i have off and let you know what happens. Thanks for the advice everyone appreciate it.
bullitt boy
NJ
You gonna drive in 1st til you get a day off? It will take you 5 minutes to diagnose this if it is the linkage. Now get out there and jack the car up slide under on your back with a flashlight and inspect the shift linkage from where it comes out under the shifter to where it connects to the trans.
Report your findings back.
