Snakebyte94
Well finaly bought the Fays2 watts link. I'm nervous and happy at the same time. I hope everything goes good. Sam Strano rocks.
does the watts link get rid of that "wiggle" under hard lateral loads or under throttle lateral loads?
if is that just inherent with the design of the car. I know some other cars have the same feeling.
pcdrj, I haven't driven a torque arm Mustang, so I can't say how much sooner I could get on the throttle with it over my set up. I'm sure the torque arm works as advertised. I will say, however, that the wiggle I'm asking about isn't throttle induced at all. The rear stepping out on throttle is one thing, the rear wanting to dance the jig on heavy braking is very-very different. (Ok, I'm exaggerating, but you get the idea.)
Also, when you say you replaced the factory 3rd link, do you mean you went from the OEM parts to the torque arm, or that you switched from a 3rd link configuration (run with aftermarket parts) to the torque arm? Just curious to hear more about your experience.
Best,
-j
Hmmm...Sleep, I had actually hoped the Watt's would diminish or eliminate that particular characteristic. But you say it's still there. Damn.
I think you're right, it's something just built into the car...or it's something we're all doing wrong in our set up. I know from my experience that the brake-wiggle can be pretty awful when I really stand on the clamps, but if I'm braking with a bit more finesse it never really rears its head.
I keep thinking that brake dive is the culprit and stiffer springs would take care of it, but Dave's running some pretty stiff springs and says (though brake dive is minimal) he still gets some of that wiggle. And we're both running rod ends, so bushing compliance isn't a likely candidate.
Q: Did you notice any benefit in this regard (hard braking) when you moved to the Watt's?
Best,
-j
The arc motion of a PHB arrangement means the body is not only moving up and down, but also side to side. And the more the body moves, the more lateral movement you'll get.
Doesn't it make sense that the move well controlled the axle or body is, the more stable the car feels?![]()
First off, a clarification...
Yes, even with a reasonably high-end suspension package, with a full complement of rod-ends in the rear, under HEAVY braking, there is still a slight "wiggle", but it is orders of magnitude less than it was with lighter springs and cheaper dampers. The ASTs are really the cat's ass, particularly coupled with higher-rate springs.
I honestly don't think the PHB is the culprit, though. Yes, as the car face-plants itself under 1G braking, the rear end will rise, causing the axle to shift, slightly, as the PHB swings through it's arc. For the rear to wiggle, however, that implies a rapid oscillation of the PHB arc, which then presupposes very rapid suspension cycling through jounce and rebound. That ain't happening. Period. My rear axle is about as positively located as it can get, with ZERO bushing deflection anywhere, excepting the rubber bushing at the top of the axle housing. I still have a minor wiggle, but I think we can rule out the body shifting around over the axle as the cause. As was mentioned earlier, by PCDRJ, even with a Watts link in back, he still had some wiggle. The only apparent choice of kit to eliminate the wiggle altogether is to swap over to a torque arm setup. The TA eliminates the upper control arm, replacing it with a considerably longer suspension member rigidly fixed to the rear axle, and pivoting at approximately the end of the tailshaft housing. This would seem to indicate that the culprit is in the 3rd link geometry, perhaps linked to the pinion angle.
