tmcolegr
It's All About the Build
when i search this part number = F7UZ-8509-AA
there is a pulley it lists for 4.6, and 5.4 and all these different applications, which one do i need?
You need the part# I posted - F7UZ-8509-AA
If you haven't already done so, I also recommend replacing the Saleen supplied 76mm smooth guided idler pulley next to the power steering pump with an OEM 90mm metal smooth non-guided idler pulley (OEM Part# 1L2Z-8678-AB or Gates/NAPA part# 38001) at that location. The plastic pulley will fail leaving you stranded. The larger OEM metal pulley, besides being more "robust", will give you more belt wrap on the crankshaft pulley reducing belt slip. If you go this route you will need a slightly longer belt. Once you have decided exactly which pulley combination you will run, let me know and I can most likely supply you with a belt part number because I've tried them all.
PS: not disagreeing with what others have posted about using a 8 or even 10 rib setup but I am running a 6 rib setup at 15 psi and have little if any belt slip. However, you must have the right pulley combination, belt tensioner and proper belt tension.
Thanks for the awesome exact down to the part # help. Rep for you !
