Cone Sweeper
Track Whore
Ok.. the fail is strong with me it seems as of this past month or two. So on the way home from work, i'm merging onto the highway and at about 50mph or so the rear end made a weird noise and then jerked and released. I slow down and pull to the side. No noise's from the rear end or clunking. So i attempt to drive again, now I seem to have a whine/squeal when giving it gas coming out of first gear and in between shifts when I push in the clutch and release it.
Now this being said, couple days ago I had to replace the pinion seal on the car because it was leaking. A shop had done it for me because of lack of tools and place to work on the car at the time. Any ideas of what could be up? They did change my pinion angle b/c they claimed it was 10 degree's ..which is kinda off seeing as i've never had a problem with the angle before and when it was set the first time it was perfect. Some help or advice would be awesome.. thanks..
Awesome... so you think it could be the pinion and ring gear that i might need to replace now..? which would be roughly how much?
