Mastering the art of the S197 3 link suspension (sixty foot)
fin1
Pittsburgh, PA
Very impressive 60'! So you guys don't use an anti-roll bar? Makes me think ARBs are overrated. I'm using a TRZ unit now, and I've considered removing it. It's a great piece and very well made, but probably best for an all out race car--it's too damn noisy for me (makes the back-end really stiff and rattles on almost every bump).
No, neither Will (Redfire) or run an anti-roll bar.
pacettr
PJ Lover
Yukon, OK
1.63
3650
McLeod RST
Stock PJ Saleen suspension
Front sway bar removed
M&H 18" DR's on 18x9 FGT wheels
FGT 18x9's with BFG KDW's up front
Leaving at 4000-4500
Switching to 17" Bogart big/littles, hoping for 1.50's
New PB on the Bogart setup with MT Et Streets: 1.596
rodfarva
Kentucky
Still not satisfied, but my best so far in my Whippled GT500 is 1.47. I've managed this time twice.
Which...
- Shocks
---Tokico D-Specs (2 turns from full soft in front, 1 turn from full
firm in rear)
- Springs---Cobra Jet front and rear
- Lower control arms--UPR with rod ends; CHE relocation brackets
- Upper control arm--UPR with urethane bushing
- posi---Stock
- Pan hard bar--J&M aluminum with rod ends
- Pan hard bar support brace--stock
- Gear size--3.73
- Brand/ tire size--Mickey Thompson 28x10.5/15 stiff-sidewalled slicks
- Clutch or which converter at what stall?--stock clutch
- Anti roll bar or which rear sway bar--BMR anti-roll bar
Bogart GT series wheels 15x10 rear and 17x5 front
Front Swaybar removed
Launch at 5000 rpm with 10.5 psi in slicks
RedFire07GT
11sec N/A 3V
Ocean County, NJ
07 GT Stick Car
-Stock Shocks
-Stock UCA
-Stock Clutch
-Detroit Truetrac
-FRPP 4.10
-CHE Tubular Lowers
-FRPP Springs
-BMR Adj. Pan Hard Bar
-CHE Anit-Squats
-15x8&15x4 Jegs Sport Star Cast
-MT ET Street DR 27x10.5
My best 60ft was a 1.722 leaving at 4500-5000 Spinning.
Added the QA1s in the rear with a CHE Adj. UCA/Mount and got my 60 down to a 1.64. Slipping the clutch at 5000RPMs
boss 245
Just saw this, a lot of differing part brands, but a lot of the same mods.
1.609 (v6 auto)
- Shocks---QA1 single adj, 3 turns each from soft
- Springs---vogtland leveling for v6
- Lower control arms--J&M billet
- Upper control arm--UPR double adjustable
- posi---auburn
- Gear size--4:10
- Brand/ tire size--Mickey Thompson 17 inch rim 28 inch diameter ET Street Drags
- Clutch or which converter at what stall?--2300 stall
- Anti roll bar or which rear sway bar--05 GT anti-sway bar
- BMR anti-squat brackets
- BMR panhard bar relocation bracket
- T/A girdle
17inch bullit replica rear, Greg Weld 15 inch fronts
router
Pro Dyno Racing
Hickory NC
60' 1.47
- Shocks Adj D Spec, tried all kinds of settings, front stiff and rear soft seems to work the best for us
- Front and Rear springs Cobra Jet
- Lower control arms Steeda
- Upper control arm Adj Steeda
- posi Tru Trac w/Moser Axels
- Pan hard bar Stock
- Pan hard bar support brace Stock
- Gear size 3.73
- Brand/ tire size MT 28 x 10.5 x 15
- Clutch or which converter at what stall? Mcleod RXT
Launcing @ 5000 RPM
- Anti roll bar or which rear sway bar stock, just relocated
Also BMR Sub Frame Conn, helped a bunch also I think
BMR Tech
Traction Vendor
Tampa, FL
Very Interesting Chuck.
Seems to be working pretty decently huh?
I think that size tire, and the extra weight on your nose makes those settings react a little better then the '"average Joe" combination.
router
Pro Dyno Racing
Hickory NC
Kelly, Yea the 60" is not bad, I think I still maybe able to get a high 1.3 out of it. Just went to a WOT box also, so working out those issues now also. I highly recommend the Sub Frame Conn from you guys, Before, the torque boxes were making so much noise I thought I broke the seat on the first pass with the slicks. LOL
BMR Tech
Traction Vendor
Tampa, FL
Ha!
Yes, our subframes work exceptionally well for both drag and road racers.
Well good luck with the new parts, keep the site updated! I'll be sure to follow your results.
rodfarva
Kentucky
Which...
- Shocks---Tokico D-Specs (2 turns from full soft in front, 1 turn from full
firm in rear)
- posi---Stock
- Gear size--3.73
60' 1.47
- Gear size 3.73
Launcing @ 5000 RPM
This looks very similar.
router
Pro Dyno Racing
Hickory NC
Yea, very close, you had any luck with the anti roll bar? I keep hearing people saying they are making a lot of noise if you are driving on the street.
Matt D
S197 Pilot
Toronto,Canada
It's not that bad, It's worth every bit of noise tbh. It works champs lol
screamingstang
bmr k member
bmr anti sway bar
bmr lowers controls
410 gears
che brackets
stock upper
eibach lowering springs
big and lil's 26x8.5 15's hoosiers
got me a 1.660
BMR Tech
Traction Vendor
Tampa, FL
Will Do, I keep seeing info on Anti Squat brackets, do those help?
It depends.
Some combos act differently.
A light, high rpm n/a combo might not see as much benefit as a 700+ RWHP lower launched, heavier poweradder combo.
Your combo, I believe they would work well.
cobra mike
rice killer
amelia va
1.80
everything stock down to the tires except for upr lower contol arms
manual car factory 3.73
good track!
RetroGT2006
06 S197 Member
Florida
- 1.896 60ft
- Transmission 5r55s
- Shocks
STOCK
- Rear springs FRPP LOWERING SPRINGS
- Lower control arms BMR + RELOCATION BRACKETS
- Upper control arm STOCK
- posi STOCK
- Pan hard bar STOCK
- Pan hard bar support brace STOCK
- Gear size 3.73s
- Brand/ tire size Michelin Pilot Sport A/S Plus 235/50/18s
- Clutch or which converter at what stall? STOCK converter, leaving at around 1300rpms.
- Anti roll bar or which rear sway bar Roush Stage 3 swaybar
Have NOT run the car since the new sway bar(doubt it will do anything for me, but i now run a 285/35/18 out back (street tire, nitto 555s). Before i run again, i will have the BMR radiator support and no front sway bar.
tbi0904
Huntley, IL
Stock 3650 and clutch
BMR LCA & UCA
BRM panhard bar
BMR K member and A arms
Dspecs full soft up front, full hard out back
3.73's (otherwise stock rear end)
Mickey Thompson drag radials 275/40/R18(12 psi)
Best 60: 1.73
I launch at around 3500. Doesn't spin but bogs off the line. I'm open to any rpm suggestions. I've tried 3800 and 4000 but spin really bad.
