Which springs should I get?
What springs should I go with?
  • Steeda Ultra Lite
    Votes: 20 87.0%
  • Roush Extreme
    Votes: 0 0.0%
  • Something else (explained in post)
    Votes: 3 13.0%
  • You are a tool, if it ain't a performance mod then don't do it!
    Votes: 0 0.0%
  • Total voters
    23
GRAYPNY
Rich
NorCal - Chico
Roush front and rear springs. Roush struts and shocks. I think it dropped the front about 1" and rear 1.25".
shatter
White And Nerdy
Northern California
I called Roush today to find out what the spring rates are for the Roush Extreme springs to see how they compare to the Steeda Ultralites. The person at Roush said that that is proprietary information and they wouldn't tell me. I just want compliant springs that will give me an OEM style ride with a drop in ride height! Why all the secrecy crap?!?!
I know the Ultralites are 195 lb front / 175 lb rear and the OEM springs are 165 lb front and 142 lb rear. I figure if the Roush came in closer to the OEM rates than the Steedas that I would go with the Roush, otherwise stick with the Ultralites.
I see in the Roush catalogue that they say the Extreme springs lower the car 1.25-1.5" though elsewhere it says 1-1.25". I think I am going to just go with the ultralites since I see them used tons and everyone on here says it is good stuff!
shatter
White And Nerdy
Northern California
Assuming I got the Steeda Ultralites. Am I going to get a smoother ride going to the Steeda, Tokico, Brand X dampers than from the stock ones? Or in other terms, is there any real benefit for a non-track car looking for a purely cosmetic lowering mod in going with aftermarket struts/shocks?
Thanks!
cekim
Large Member
Earth
I doubt any aftermarket setup will be "smoother". But "smooth" certainly...
The benefit to lowering a non-track car is that it will be more fun to turn... Lower CG, better progressive rate, etc... All that equates to jerk the wheel and the car just turns without hesitation or roll... Once you have ridden in a car that really knows how to turn, you will understand why this is fun even off the track...
"smoother" than the relatively mushy stock setup just isn't on many people's radar screen - Ford already made it as squishy as anyone would want it...
I have Roush springs in one of my cars and they are pretty nice to drive on as well - firmer than stock, but a world away from the Eibachs. I have ridden on The ultra-lites, but I have to admit I wasn't paying attention - I did not notice them one way or the other...
shatter
White And Nerdy
Northern California
Installed the springs today!
Put the Steeda Ultralites in today with CaliHPAddict's and Graypny's help. Cali hooked us up with a simple method to drop the front springs without using a spring compressor, everything went smooth. The rears were super simple to swap out. Here are some before/after pictures (before car being driven or the springs having time to settle etc.) Only down side is it makes me want wider tires now! Ride was firmer but not harsh at all, very nice indeed.
Thanks everyone for your advice and help!! Steeda = good :clap:
oman_cobra
Lethal Mustang
Steeda, im buying them soon.
personally, i believe almost in all steeda products..
C-Liz-Go
Resident Realtor
Houston
I did the Roush rear springs only. No need to change any other suspension parts (i.e. panhard rod). No noticable harshness or real comfort in the drive. Main benefit is it is a cheaper/easier, and for me it accomplished my main goal which was to lower the rear because stock it sits way too high.
You know, it's funny about what you say regarding the gap. I am so used to seeing my wheel wells filled with tire, that when I see a stock GT, I'm like "DAMN, that's a lot of empty space"...but yesterday I DID slam the subframes into a driveway that was higher than expected.
TexasKyle
D.I.L.L.I.G.A.F
Katy, Tx
You seem to have the worst luck with that sort of thing Liz. :)
Looks great Shatter!
