IA_Chiefs_fan
- Joined
- Mar 11, 2010
- Posts
- 70
- Reaction score
- 0
I recently purchased 52 specialty tool kits from a dealership that closed. I finally got an inventory list put together but I haven't had a chance to price the kits. If there's something you're interested in let me know and I'll see what kind of deal I can give you. Half the kits are in this post and half are in Post #2. All kits come with the plastic red cases unless otherwise noted. Many of them have sealed workshop manuals that are specific to each kit.
I rent out the 3V Valve Spring Compressor 303-1039 and 303-1175 Timing Chain Wedge. I will also sell them for the right price.
TKIT-2008ET-FIM
Escape/Mariner/Hybrid
307-633/2
307-636
Valve Body Alignment Pins
307-634
Turbine Shaft Seal Installer
307-635
Turbine Shaft Seal Protector
307-628/1
PROTECTOR,LOW/REV PISTION SEAL
307-628/2
PROTECTOR, CENTER SUPPORT SEAL
TKIT-2008ET-FLM
Ranger, Fusion/Milan/MKZ, Focus, Escape/Mariner/Hybrid, F-150, Explorer, Mountaineer, Sport Trac, Expedition, Navigator
303-1417
2.5L
TOOL, CRANK SENSOR ALIGNMENT
303-1416
2.5L
TOOL, CRANK DAMPER HOLDING
307-637
INSTALLER, 4X4 REAR SEAL
307-638
INSTALLER, 4X2 REAR SEAL
307-639
INSTALLER, 4X2 REAR BEARING
303-1418
3.0L
COMPRESSOR, VALVE SPRING
Hem Flange Tools for TSB 01-07
Econoline, F-Series Truck (no case included)
501-078
Door Hem Flange
Includes 501-078/1 (right hand) and 501-078/2 (left hand) and 501-078/3 (plastic inserts [Bag of ten])
501-080
Door Hem Flange
Door Hem Flange Crimping Tool
TKIT-2007AC-FLM
2008 ESCAPE, MARINER, Hybrid, Focus
412-136
INSTALLER, A/C CLUTCH
412-137
PROTECTOR, A/C SHAFT
TKIT-2007AP-F
F-Super Duty 250-550
310-184
6.4L Diesel
AIR PURGE ADAPTER, FUEL SYSTEM
TKIT-2007FI-FLM
5.4L INJECTOR TEST TOOL
310-190/1
5.4L 3 Valve Engine
100ML LOW FORM BEAKER X 8
310-190/2
5.4L 3 Valve Engine
STOPPER X 8
TKIT-2006UP-FLM
2007 EXPEDITION, NAVIGATOR, F-150
205-852
BEARING RACE INSTALLER
204-608
BUSHING REMOVER
TKIT-2005D2-F
307-547/8
CVT Transmission
307-547/7
CVT Transmission
307-547/9 X 2
CVT Transmission
TKIT-2005D2-F
307-544
CVT Transmission
Transmission Fluid Pump Aligner (Includes 307-544/1, 307-544/2, 307-544/4)
307-543
307-535
CVT Transmission
307-565
CVT Transmission
TKIT-2005D3-F
Expedition, Navigator, Freestyle, Montego (no case included)
204-589
Control Arm Bushing Installer/Spacer Assembly (includes 204-589/1, 204-589/2, 204-589/3)
TKIT-2005U-F
Taurus/Taurus X/Sable, MKS, Flex, Escape/Mariner/Hybrid (no case included)
205-816
Dana 28 Rear Axle
Differential Oil Seal Protector (pair)
412-133
Climate Control System
Compressor Clutch Pulley Holding Fixture
TKIT-2004J-F
Mustang, F-150, F-Super Duty 250-550, Explorer/Mountaineer/Sport Trac, E-Series, Expedition/Navigator, Crown Victoria, Grand Marquis, Town Car, Taurus/Taurus X/Sable, Fusion/Milan/MKZ, Flex
205-086-01
Propshaft Driveshaft
Adapter for 205-086 (Bridge Assembly)
303-1040
4.6L 3V, 5.4L 3V
Cylinder Head Alignment Pins (pair)
418-F395
Restraint System
Restraint System Diagnostic Service Tool/Air Bag Simulator(pair)
310-122
Fuel System (4.6L and 5.4L 3V Engine)
Fuel Pressure Gauge Connector
TKIT-2003D-TBIRD
Thunderbird Axle Kit
205-540
Driveline
Differential Bearing Gauge
205-537
Driveline
Axle Bushing Remover
205-541
Driveline
205-539
Driveline
Rear Halfshaft Seal Installer
205-538
TKIT-2002N-DEW
205-485
Aluminum Axle Bushing, Differential Cover Subframe Mount Bushings, Nodular Axle Bushing
(INCLUDES 205-485/1, 205-485/2, 205-485/3, 205-485/4, 205-485/6 & 205-485/7)
Recall / ONP 00531
2000 Focus (no case included)
204-304
Axle Shaft
Drill Bit and Guide
T99L-1000-F
Crown Victoria/Grand Marquis, Town Car, Ranger, Mustang, F-150, Explorer/Mountaineer/Sport Trac, Expedition/Navigator, F-250, F-350, Taurus, Sable, Continental, Windstar
205-453
10.5 Inch Rear Axle
PINION RUNOUT GAUGE
303-634
4.0L SOHC
KEYLESS JACKSHAFT TOOL
412-127
HEATER HOSE DISCONNECT TOOL
205-454
10.5 Inch Rear Axle
PINION RUNOUT GAUGE PIN
303-636 & 637
2V engines
TIMING CHAIN WEDGE AND HANDLE
205-460
8.8 Inch Rear Axle
PINION THREAD PROTECTOR
307-393
AX4N AX4S
PUMP SEAL AND BEARING ASSEMBLY INSTALLER
501-052
Air Bag
ANTI-THEFT SOCKET
307-394
AX4N AX4S
PUMP SEAL AND BEARING ASSEMBLY REMOVER
501-S042
DOOR GLASS BLOCK SET(INCLUDES 501-045, 501-044 & 501-043)
T96P-1000-B
Escort, Tracer, Aspire, Probe
T96P-12A650-B
BREAKOUT BOX ADAPTER
T96P-12A650-C
T96P-50-A
AIR BAG SIMULATOR
TKIT-1996-F/FM/FLM
Mustang
308-245 (T96P-7050-A)
T45
Transmission Tube Guide
308-240 (T96P-7025-B)
T45
MAINSHAFT BEARING CUP INSTALLER/REPLACER
308-241 (T96P-7025-C)
T45
INPUT SHAFT BEARING CUP INSTALLER/REPLACER
308-243 (T96P-7025-E)
T45
Hub Removal Collett Sleeve / Transmission Synchronizer Remover
308-242 (T96P-7025-D)
T45
308-244 (T96P-7025-F)
T45
SHIFT RAIL BUSHING INSTALLER/REPLACER
308-239 (T96P-7025-A)
T45
Mainshaft/Input Shaft Bearing Cup Installer/Replacer
105-00012
AIR BAG SIMULATOR
211-327
Power Steering System
Crown Victoria/Grand Marquis, Town Car, Taurus/Taurus X/Sable, Ranger, Mustang, MKS, Fusion/Milan/MKZ, Focus, Flex, F-150, F-Super Duty 250-550, Explorer/Mountaineer/Sport Trac, E-Series, Expedition/Navigator Power Steering Vacuum Fill Tool (no case included)
T95P-1000-FH-FLMH (TKIT-1995-FH/FLMH)
Crown Victoria/Grand Marquis, Town Car, Mustang, F-150, F-Super Duty 250-550, Explorer/Mountaineer/Sport Trac, E-Series, Expedition/Navigator, Ranger, Taurus, Taurus X,Sable, Mustang, MKS, Fusion, Milan, MKZ, Flex, Escape, Mariner, Hybrid
303-518 (T95P-6701-DH)
4.6L 2V, 4.6L 4V, 5.0L, 5.4L, 5.8L, 6.8L
Crankshaft Rear Oil Seal Installer
204-186 (T95T-5638-AH)
Dana 35 IFS
Front Differential Housing Bushing Remover
303-516 (T95P-6701-BH)
303-519 (T95P-6701-EH)
2.5L, 3.0L 4V, 3.4L SHO, 4.2L, 4.6L 2V, 4.6L 4V, 5.0L, 5.4L, 5.8L, 6.8L
Crankshaft Rear Oil Seal Remover
204-187 (T95T-5638-BH)
Dana 35 IFS
Front Differential Housing Bushing Installer
204-188 (T95T-5638-CH)
Dana 35 IFS
Front Differential Housing Bushing Aligner
303-514 (T95P-6701-AH)
4.6L 2V, 4.6L 4V, 5.4L, 6.8L
Crankshaft Rear Oil Slinger Remover
303-517 (T95P-6701-CH)
Crankshaft Rear Oil Slinger Installer
TKIT-1995-FLM/LT
F-150, F-Super Duty 250-550, Expedition/Navigator
205-486
Dana 80 Rear Axle
DRIVE PINION BEARING CUP INSTALLER
205-488
Dana 80 Rear Axle
DRIVE PINION BEARING INSTALLER
205-489
Dana 80 Rear Axle
DRIVER PINION INNER BEARING REMOVER
308-421
S6-650 ZF (6 speed)
CLUTCH ALIGNMENT TOOL
205-487
Dana 80 Rear Axle
DRIVE PINION THREAD PROTECTOR
T94P-1000-FH/FLMH
Taurus/Taurus X/Sable, Ranger, MKS, Fusion/Milan/MKZ, Focus, Flex, Escape/Mariner/Hybrid, Ranger, Taurus, Taurus X, Sable, MKS
303-467 (T94P-6312-BH)
2.5L, 3.0L 4V
WATER INLET TUBE REPLACER
794P-6256-DH
CAMSHAFT DAMPER REPLACER
T949-6510-AH
VALVE STEM SEAL REMOVER
303-471 (T94P-6510-DH)
2.0L, 2.0L 16V
VALVE GUIDE INSTALLER
303-470 (T94P-6510-CH)
2.0L, 2.0L 16V, 2.5L, 3.0L 4V
VALVE STEM SEAL REPLACER
303-463 (T94P-6256-AH)
2.5L
CAMSHAFT SEAL PROTECTOR
303-464 (T94P-6256-BH)
2.5L, 2.5L OHC
CAMSHAFT SEAL REPLACER
303-456 (T94P-6312-AH1)
2.5L, 3.0L Duratec
Water Pump Pulley Plate
303-457 (T94P-6312-AH2)
2.5L, 3.0L Duratec
Water Pump Shaft Protector
303-458 (T94P-6312-AH3)
2.5L, 3.0L Duratec
Camshaft Pulley Installer
303-459 (T94P-6312-AH4)
2.5L
Water Pump Pulley Spacer
303-472 (T94P-6565-AH)
2.0L, 2.0L 16V
VALVE SPRING COMPRESSOR ADAPTER
303-462 (T94P-6136-AH)
2.5L, 2.5L OHC, 3.0L 4V, 3.4L SHO
CONNECTING ROD GUIDES (2)
308-221 (T94P-7025-BH)
MTX-75
BEARING CUP REPLACER
308-222 (T94P-7025-CH)
MTX
DIFFERENTIAL DRIVESHAFT SEAL REPLACER
308-224 (T94P-7025-EH)
MTX
PINION SPINE SOCKET (Functionally similar to 205-175)
308-225 (T94P-7025-GH)
MTX
DIFFERENTIAL BEARING CONE REPLACER
T94P-7025-FH
GEAR LEVER ALIGNING TOOL
308-223 (T94P-7025-DH)
MTX
SELECTOR SHAFT BEARING REMOVER/REPLACER
T94P-6000-AH
POWER TRAIN ALIGNMENT GUAGE
308-S217 (T94P-4451-BH)
MTX
SHIM SELECTION TOOL ADAPTER (INCLUDES BH1 & BH2)
308-216 (T94P-4451-AH)
MTX
DIAL INDICATOR MEASURING FIXTURE (WITH BOLTS) (Functionally similar to 308-194A)
307-S285 (T94P-77000-E)
CD4E
SERVO PLUG REPLACER/NEEDLE BEARING RECEIVER
T94P-77000-A1 (TKIT-1994-F&FLM/FM)
T94P-77000-N
CD4E
VALVE BODY GUIDE PIN (ONLY 1)
T94P-77000-S
CD4E
TRANSMISSION TEST PLATE
T94P-77000-J
CD4E
SPRAG REPLACER
307-S305 (T94P-77000-U)
CD4E
LUBE TUBE REPLACER SET
T94P-77000-T
CD4E
SHIM SELECTION DEPTH GAUGE
T94P-77000-V
4F20E, CD4E
END PLAY CHECKING TOOL SLEEVE
T94P-77000-K
CD4E
NEEDLE BEARING INSTALLER
T94P-77000-G
CD4E
PUMP REMOVAL BOLTS
307-291 (T94P-77000-H1)
CD4E
SHIFTER SHAFT ALIGNMENT TOOL
307-292 (T94P-77000-H2)
CD4E
SHIFTER SHAFT ALIGNER
T94P-77000-R
CD4E
PRELOAD TOOL ADAPTER/ALIGNER SET
307-304 (T94P-77000-R1)
CD4E
SHIM SELECTION PRELOAD PLATE
307-304-01 (T94P-77000-R2)
CD4E
Adapter for 307-304
307-304-02 (T94P-77000-R3)
CD4E
Adapter for 307-304
307-304-03 (T94P-77000-R4)
CD4E
Adapter for 307-304
T94P-77000-E
307-286(T94P-77000-E1)
CD4E
INSTALLER, NEEDLE BEARING REMOVER
307-287(T94P-77000-ER2)
CD4E
SERVO PLUG REMOVER, INSTALLER
T94T-6379-AH
F-Super Duty 250-550 DAMPER SERVICE SET
303-486 (T94T-6701-AH1)
7.3L Diesel (DIT)
Crankshaft Rear Wear Ring Remover
303-487 (T94T-6701-AH2)
7.3L Diesel (DIT)
Crankshaft Rear Wear Ring Guide
303-477 (T94T-6002-AH)
7.3L Diesel (DIT)
KEYSTONE PISTON RING GAUGE SET
303-493 (T94T-9395-AH)
7.3L Diesel (DIT)
FUEL/OIL/TURBO PROTECTOR CAP SET (only 1 cap missing)
303-S479 (T94T-6379-AH)
7.3L Diesel (DIT)
Crankshaft Vibration Damper Service Set (Includes 303-480 thru 303-482)
303-483 (T94T-6513-AH)
7.3L Diesel (DIT)
VALVE SRPING COMPRESSOR
TKIT-1994-FH/LTH
Windstar
309-001 (T94T-6000-AH)
3.0L 2V Vulcan, 3.8L, Exhaust System
Flexible Exhaust Pipe Holding Fixture
007-00108
4WABS DIAGNOSTIC HARNESS ADAPTER
T93L-1000-FH/LTH (TKIT-1993-FH/LTH)
T93T-2100-AH
DOOR LATCH CABLE ADJUSTMENT TOOL
T93L-77110-AH
CASE CENTER SUPPORT REMOVER/REPLACER
T92T-1175-AH
Dana 80, Dana 80 Limited Slip, Dana 80 Locking Axle
Hub Seal Replacer (no case included)
TKIT-1992
007-00052
MECS SELF-TEST ADAPTER
007-00083
TFI IV CABLE PIP ADAPTER
T92C-6000-AH
AH BREAKOUT BOX ADAPTER
TKIT-1992-FMH-FLMH
Villager
007-00053
Engine
007-00054
4F20E Transmission Control Module
007-00055
ABS Module
TKIT-2008ET-FIM
307-633/2
307-636
307-634
307-635
307-628/1
307-628/2
TKIT-2008ET-FLM
303-1417
2.5L
303-1416
2.5L
307-637
307-638
307-639
303-1418
3.0L
501-078
Door Hem Flange
501-080
Door Hem Flange
TKIT-2007AC-FLM
412-136
412-137
TKIT-2007AP-F
310-184
6.4L Diesel
TKIT-2007FI-FLM
310-190/1
5.4L 3 Valve Engine
310-190/2
5.4L 3 Valve Engine
STOPPER X 8
TKIT-2006UP-FLM
205-852
204-608
BUSHING REMOVER
TKIT-2005D2-F
307-547/8
CVT Transmission
307-547/7
CVT Transmission
307-547/9 X 2
CVT Transmission
TKIT-2005D2-F
307-544
CVT Transmission
307-543
307-535
CVT Transmission
307-565
CVT Transmission
TKIT-2005D3-F
204-589
TKIT-2005U-F
205-816
Dana 28 Rear Axle
412-133
TKIT-2004J-F
205-086-01
303-1040
4.6L 3V, 5.4L 3V
418-F395
Restraint System
310-122
TKIT-2003D-TBIRD
205-540
Driveline
205-537
Driveline
205-541
Driveline
205-539
Driveline
205-538
TKIT-2002N-DEW
205-485
Recall / ONP 00531
204-304
Axle Shaft
Drill Bit and Guide
T99L-1000-F
205-453
10.5 Inch Rear Axle
PINION RUNOUT GAUGE
303-634
4.0L SOHC
412-127
205-454
10.5 Inch Rear Axle
303-636 & 637
2V engines
205-460
8.8 Inch Rear Axle
307-393
AX4N AX4S
501-052
Air Bag
ANTI-THEFT SOCKET
307-394
AX4N AX4S
501-S042
T96P-1000-B
T96P-12A650-B
T96P-12A650-C
T96P-50-A
AIR BAG SIMULATOR
TKIT-1996-F/FM/FLM
Mustang
T45
T45
T45
T45
T45
T45
T45
105-00012
AIR BAG SIMULATOR
211-327
Dana 35 IFS
Dana 35 IFS
Dana 35 IFS
TKIT-1995-FLM/LT
205-486
Dana 80 Rear Axle
205-488
Dana 80 Rear Axle
205-489
Dana 80 Rear Axle
308-421
S6-650 ZF (6 speed)
205-487
Dana 80 Rear Axle
T94P-1000-FH/FLMH
2.5L, 3.0L 4V
794P-6256-DH
T949-6510-AH
2.0L, 2.0L 16V
2.5L
2.5L, 2.5L OHC
2.5L, 3.0L Duratec
2.5L, 3.0L Duratec
2.5L, 3.0L Duratec
2.5L
2.0L, 2.0L 16V
MTX-75
MTX
MTX
MTX
T94P-7025-FH
MTX
T94P-6000-AH
MTX
MTX
CD4E
T94P-77000-N
CD4E
T94P-77000-S
CD4E
T94P-77000-J
CD4E
SPRAG REPLACER
CD4E
T94P-77000-T
CD4E
T94P-77000-V
4F20E, CD4E
T94P-77000-K
CD4E
T94P-77000-G
CD4E
PUMP REMOVAL BOLTS
CD4E
CD4E
T94P-77000-R
CD4E
CD4E
CD4E
Adapter for 307-304
CD4E
Adapter for 307-304
CD4E
Adapter for 307-304
T94P-77000-E
CD4E
CD4E
T94T-6379-AH
7.3L Diesel (DIT)
7.3L Diesel (DIT)
7.3L Diesel (DIT)
7.3L Diesel (DIT)
7.3L Diesel (DIT)
7.3L Diesel (DIT)
TKIT-1994-FH/LTH
Windstar
007-00108
T93T-2100-AH
T93L-77110-AH
T92T-1175-AH
TKIT-1992
007-00052
007-00083
T92C-6000-AH
TKIT-1992-FMH-FLMH
Villager
007-00053
Engine
007-00054
007-00055
ABS Module
