And exactly how do you know for sure that these "extended needs" will be absolutely needed?
I mean your coming off as if you have done the testing and know for a fact that parts will fail if the car is shifted above 7500rpms when in fact you really dont have any information other then speculation that this will happen.
You might be absolutely right and dead on with your speculation but until its proven that valvetrain upgrades are needed or not your opinion is just that, speculation.
We do agree on the clutch however I doubt your going to see any "catastrophic" or "dangerous" failures with the stock clutch, you will just see what we have already seen and thats cars that wont shift because the clutch cant handle it.
Yes a numerically low gear ratio car with an auto shouldnt get this intake and would be slower but as I said, most modded cars that use this intake will be faster. Ours has 3.73's back in it and feels a ton stronger in all rpm's and there is no noticeable torque loss even though it shows in the graph.
We are here to test this unit and I will do my best to break whatever I can in an attempt to show what the consequences of using this intake and shifting at a higher rpm might be, but until I or someone else starts breaking stuff its irresponsible to "warn the community" about something you really dont have any information on.
I appreciate your thoughts, input and opinions.
Thanks,
JJ
