Irishman
Ricer
I'm in the process of building my car up and will have the motor out this spring and would like to know what everyone is running. I would like to keep from bringing the power to the higher rpm to much. Is there anything better then stock for power down low?
It seems that most move everything to the right and with the paxton it already has that flat spot until spooled so I don't want a dog of the line.
I will be running a JDM 302E with stock compression if that helps. I also have Paxton Novi 2200SL HO Supercharger Kit
- FRPP 60 lb. injectors
- Fore Triple Return Fuel system
- Autolite HT0 Spark Plugs
- Diablo Sport MAFia
- BBK Long Tube Ceramic Coated Headers with Off Road H mid pipe.
- MAC Mufflers
- BMR Biller LCA's
- BMR Relocation Brackets (Welded in by Brenspeed)
- BMR Adjustable Pan Hard Bar
- BMR Pan Hard Brace
- Steeda Ultra Lite Springs
- McLeod RST Twin Disk Clutch
- McLeod Billet Steel Flywheel
- 4.10 gears
- Maybe GT500 TB and FRPP Intake
- MAC Mufflers
- BMR Biller LCA's
- 4.10 gears
Oh well she will get over it. Wait till she finds out about the TR6060 next
I will probably not do cams until I can have everything I need to support what I have. I need to get the TR6060 next and all the other parts for shortblock swap.
