failed emissions in IL
zxmarekxz
NE IL
sorry i couldnt help, but with the EPA busting down, im not interested in getting involved.
makes sense.
Kind of funny, but i was just on your site. Have you guys completely moved to Georgia, or still do some work in IL?
tx
Bob_Kurgan
makes sense.
tx
yup, completely moved to GA... i am coming back multiple times this summer for tuning sessions though
Bob_Kurgan
Has something recently changed?
no, but when it becomes high profile and a huge thread about it, i dont want to be involved... draws too much attention. Basically, it was just posted that Tim broke the law...
v8venomgt
round lake, il
people should keep pertinent/sensitive info out of the public eye, and resort to pm if things seem questionable. good luck out there bob!
TotoGT06
SE Wisconsin
So do you have to drive so many miles if you retuned or got codes cleared before you can get tested so sensors are running? I just got my cats in and retuned for the rear O2s to be on and only had a couple miles on the tune with any previous codes cleared and I was rejected again. Figured maybe it was the little miles on the new tune but what do you guys think?
Teege24
Mchenry, IL
you should drive around for about 30 mins after loading the tune...
TotoGT06
SE Wisconsin
i believe its 15-20 min highway speeds not dropping below 55 mph, and 15-20 min in traffic/street driving
Okay because im freaking out since i have got the cats in it now and im over due on emissions just trying to get the car legal again
BMWM3
Always Online
Cordova, Tn
Wish i would have followed your post, I have custom fitted JBA high flow cats that work with mac long tubes. I bought them a year ago and found out that i didn't have to go through inspection b/c of where i live, they have 25 miles on them.
TotoGT06
SE Wisconsin
Anyone else able to confirm amount of time driving or distance driven after a tune is loaded or the codes are cleared? Im trying to drive around as much as I can on this emissions tune without running into a cop to get it ready for emissions
KemahGT
Try your local Auto Zone or other parts store. Many will lend you an OBD scan tool that has little green lights for emissions status. You can also buy them for around a hundred or so. When you see green, HAUL ASS to the inspection station. You'll do fine.
TotoGT06
SE Wisconsin
And this acts differently than a normal scanner tool like from snapon?
KemahGT
What you want to look for is one that tells you your emissions controls status. If you clear all DTCs and then reset your ECM by disconnecting your battery for a few minutes, plugging into a states OBD-II tester will give you a bunch of "Not Ready" codes. By driving the learning cycle these various systems will go to a "Ready" state (and then "Fail" if you are having problems). A reader that you can use that tells you when you are "Ready" for these various systems will be what you need.
My SCT2 clears codes but will not give "Ready" vs, "Not Ready" status (unless I'm missing something). Use one of these and you can look for the green lights to show "Ready" states:
http://www.equus.com/Product/Detail/81458BCD-829C-4365-872C-02EEEB5B38E0
In Texas you are allowed one "Not Ready". Any more than that and you will fail. On my last inspection I clearly did not drive it long enough because I had a "Not Ready" for my EVAP system. This was my only "Not Ready" so I still passed.
Snap-on probably has one that will do the job. There are many of them out there. Just be sure it gives you emissions status.
To my knowledge there is no "trick tune" that will make rear O2 sensors give a "Ready" when they are not there. Search exhaust hacks to find a way to make a system think you have cats.
