Roush M90 issue
06RFSTANG
New York
I just finished installing my supercharger yesterday and got the car running.My problem is the temp gauge is not working at all and the fan is running at all times right from start up.Check engine light was on and I pulled the code
P1290-engine cyl head temp sensor high input
I tried to search first but couldnt find any definitive help.Thanks in advance for any help.
one eyed willy
Pizzle fo shizzle
Lakeland FL
temp sensor is in the passenger side head, on the inside of the valley. it would be under the supercharger.
its that sensor with the white plug in the bottom left
06RFSTANG
New York
I didnt touch that sensor or disconnect it at all.Unless when I put the manifold on something happened.Would that cause the problem with the gauge and the fan running.Sorry I am a 45 year old newb to this stuff
did you inadvertently damage the wiring attached to the CHT sensor?
This
You may have pinched the wire between the intake manifold and the block causing it to short.
06RFSTANG
New York
Looks like I have to pull it off and start over again.Was hoping for an easy fix but nothings ever easy is it.
one eyed willy
Pizzle fo shizzle
Lakeland FL
try reaching back there with your hands and see if the wire has any slack, you may be able to free it up. also you could try a mirror and flashlight to get a look.
Zrxpilot
Please keep posting with any updates to this. Doing this same mod myself next weekend. Good luck finding the fix. Hope its nothing big.
HOLLYWOODGT
New Lenox, IL.
I'm a Roush Dealer and have no problems with the M90. I would have to agree with whats been said sounds like a pinched wire.
irishpwr46
Official Site Vandal
NYC
who helped you drop the manifold on? i know it is a bitch to do alone and that there is a good chance you banged or pinched that sensor in the process. good luck with it, and dont get discouraged
06RFSTANG
New York
I took it apart the other night and found the problem.You guys were right,part of the sensor harness was caught between the intercooler tubes and the block when I tightened them down.Simple fix and no problems now.Thanks again
