Mastering the art of the S197 3 link suspension (sixty foot)
tjm73
of Omicron Persei 8
Rush, NY
That concern's me. I am gonna run that same suspension and eventually that gear.
Do you know if the gears were installed 100% to spec? Did they make noise before?
gotsboost
Yes the guy I had do it has done over 100 8.8's. It never made noise before the install. I will say the traction is worth it. Night and Day differance.
tjm73
of Omicron Persei 8
Rush, NY
Can the noise be covered by turning up the stereo a little more? LOL
D98GT
STREETCAR
Liberty TX
Even when adding aftermarket control arms the sound increases quite a bit (I run BMRs). I had a bearing problem and the aftermarket control arms really allowed me to hear it compared to stock
Mike K
WANNA BE FAST
Richfield, MN
I have spherical bearing end lca's and ph bar that I'm going to be installing. I'm hopeing these will help. (I know the ph bar won't help)
tjm73
of Omicron Persei 8
Rush, NY
My view on NHV is if it's not overwhelming, it's ok. I mean it's a mechanical machine. They make noises.
whippled06
Kelley Performance
virginia Beach VA
My car is a freak.lol I removed the front and rear sway bars and made an anti roll bar for my 2011 and Everything else is stock. Car has pulled 1.41 60's on 28x10.5 slicks
JP229
Washington, MO
There's almost no way of getting around whine, squeeks and yada yada when you start taking stock parts off and replacing them with the aftermarket stuff.. I did UPR upper and lower control arms and i noticed more noise from the rear. I've heard of vibration through k-members, tubular suspension and what not causing "harmonics" and making noise. Just something you gotta learn to deal with when you wanna make a street/strip car I think
JJ@WMS
Woodbine Md
Your not alone, we still have the rear sway bar and all motor have managed 1.49 60fts on the same size slick. Stock shocks/springs all the way around. Just Metco LCA's relocation brackets. I'm happy and not touching a thing. :beerchug2:
JJ
Airborne2000
11.6 1.70 60 ft.
- Shocks QA1's rear only, stock fronts.
- Rear springs
roush
- Lower control arms JDM with BMR LCA brackets
- Upper control arm lakewood adj.
- posi stocker
- Pan hard bar Eldebrock adj.
- Pan hard bar support brace Eldebrock
- Gear size 3.73
- Brand/ tire size MT DRs 275/50/15 on jegs 15x8
- Clutch or which converter at what stall? Stocker 5r55s
- Anti roll bar or which rear sway bar stock
Fake_Snake
FAUX GT500
Houston, Tx
Did i over look Lakewood 50/50 drags shocks rea and there drag front?
I didn't see anyone with them ?
Airborne2000
i think they are crap from what i have read, the QA1 and teckio seem to be the best now a days
TheSlow1
Wi
I still haven't heard anything on the strange adjustable shocks and struts for our cars. I have always had good luck with strange products so i'm assuming they will be good but looking for anyone with experience with them.
Diabolical!
Zapp Rowsdower
I bought strange's front adjustable struts (have QA1s in the rear). Compared to the QA1s, the Strange are very difficult to adjust. Other than that, they will firm and soften nicely. I need to play with my settings a bit more, but I think they will work out nicely.
TheSlow1
Wi
Thanks for the info on that. I ordered the strage front and rears a while ago and was ust wondering for when i get home off this deployment
WarFords
Billings, MT
11.057@131 1.35 60ft
- Rear springs CJ springs
- Lower control arms BMR with BMR relocation brackets
- Upper control arm Steeda Adj
- posi stocker
- Pan hard bar Steeda adj
- Pan hard bar support brace Steeda
- Gear size 3.73
- Brand/ tire size M/T drag slick 28x10.50
- Clutch or which converter at what stall? clutch with spec stage 3+
Airborne2000
- posi stocker
- Gear size 3.73
what rpms do you run through the traps at?
