How to verify both GT500 pumps are working?
dmhines
KONA GT
Cumming, GA
I installed a FRPP GT500 pump setup a few weeks back. I was driving into work this morning wondering if both pumps were actually working. Outside of datalogging how would you verify? I figured if I pulled the factory fuel pump fuse from under the hood ... then the second pump should continue to run ... therefore the car should continue to run. Think that would be a good way to verify? Anyone ever try it?
Skarkull
If I looked at the wiring correctly, you are now using the original wiring that turned on the factory pump to activate the relay. If you pull your original factory pump fuse, you'll have no power to turn on the relay. Therefore, no fuel at all.
dmhines
KONA GT
Cumming, GA
Thanks ... yes that makes sense. Glad I didn't try my method ... I would have been scratching my head when the car wouldn't start!
Unplug one fdpm at a time and key-on to prime and you will hear each pump come on.
Yep, this is the way I verified mine.
What is the issue you are looking for? Just verification or other issues? I was originally chasing down a lean issue. Turned out to be the tune and the way the tuner set up the pumps (didn't tell the car it had two).
dmhines
KONA GT
Cumming, GA
Just want to verify I installed correctly ...
Also .. I have asked Jim Jr. at JDM if he needed to update my tune for Dual Pumps. He said there is nothing for him to update in the tune for dual pumps .. they just work.
JeremyH
3V Fuel Guru
Virginia Beach
I have seen you post in the other thread about this and what JDM said but I have seen too many people with issues after swapping in a gt500 setup with no retune. And after the tune was adjusted they were good to go.
Kuro!
Banned
Austin, TX
It's called an FPR "brah".
Wouldn't the PCM adjust fuel trim and duty cycle based upon the FPR's reading?
Kuro!
Banned
Austin, TX
What sits on top of the driver side rail.
EDIT: What your saying is that there is no way for the PCM to adjust fuel trims?
JeremyH
3V Fuel Guru
Virginia Beach
Fuel rail pressure sensor.
It just reads delta pressure and sends it to the pcm then the pcm uses the fpdm to control pump speed and maintain delta pressure.
A fuel pressure regulator sits at the fuel rail and maintains a certain pressure regardless of pump speed. Most often used on return setups.
Kuro!
Banned
Austin, TX
So the PCM just regulates voltage to the FPDM based upon the delta pressure read at the rail?
I know what a "stand alone" adjustable FPR, this is interesting... thanks for the knowledge.
JeremyH
3V Fuel Guru
Virginia Beach
Sorta, the fpdm is what actually regulates voltage to the pump according to the pressure signal from the pcm.
Thats why you wire a bap pre-fpdm in our cars, that way the fpdm always has 17volt dc input and then will regulate that voltage to the pumps based on load/demand.
And the v6 doesnt even have the fuel rail pressure sensor so i know when guys do v8 swaps you have to run a vac line to the sensor for it operate properly as the frps needs to know vac/pressure in the manifold in order to send the correct fuel pressure signal to the pcm.
Kuro!
Banned
Austin, TX
Ah, makes sense. Thanks
I did Bmaxwell's set up for him, couldn't using shitty wire on the relay potentially fuck with the voltage and make the pumps act weird?
JeremyH
3V Fuel Guru
Virginia Beach
Cool, yeah i gave him alot of pointers for his setup and sold him the dual pump hat he has. Yeah you want nice wire with solid connections to ensure the best signal and have less amperage drop.
dmhines
KONA GT
Cumming, GA
I know ... I even verified with him again and he says there is nothing to tune.
Kuro!
Banned
Austin, TX
lol I know, you went above and beyond on helping.
