hollywood54
Ok guys this build has been a nightmare. Anything that can go wrong has. I have finally got to the point to crank it over and the engine will not turn. Now the engine would rotate when I was building it and I had a hard time getting the auto tran to bolt up to it so I'm thinking that the tranny is causing the problem. When I try to start the car you hear thud when the starter hitting the flex plate but its not able to turn it. I have put the car in natural and i cant turn the motor from the crank. I'm getting to the point that I'm going to take it to a shop because I'm at then end of my rope. So if yall have any ideal that will keep me from getting raped by the transmission shop I would be thankful.
