How much can u bore the coyote block
Full_Tilt
Im curious about this as well.
The last thing I would want to do would be to stroke this engine, but boring out for displacement would be great.
Id imagine you'd have to sleeve it to get any real increase though.
they are sleeved already from the factory.
the walls are pretty thin as I recall. I doubt they could be bored more then .020
KungFuHamster
Ft Worth
destroke it and rev it to the moon!! 10k shift points baby!
Full_Tilt
Obviously. You have to have sleeves in an auminum block.
Most modern engines dont have enough meat in them to get much from a dry sleeve without weakening the cylinder walls significantly.
What I meant was punching it out into the water jacket and putting in a new wet sleeve.
I would be more inclined to make custom pistons with the wrist pin moved up inside the scraper ring. Should provide a fair bit of added rod length.
Or, if youre already sleeving, weld on a deck plate to get some serious added length. The only problem would be that the intake manifold, exhaust, timing chain, and god knows what else, would no longer fit.
Hearing a cross plane V8 at 10k would be very cool though. I know its been far exceeded with flat plane engines, but Im not sure how high anybody has reliably reved a cross plane.
which is expected to handle upwards of 2,000 horsepower and nearly 8,000 RPM
I'll wait to see if that is what happens
KonaGT
I have heard of the stock block breaking at 1,000 hp on a turbo setup
