I’ve got a 2013 5.0, and have noticed that there is very bad lockout when trying to shift at any rpm’s higher than about ~6k in every gear pretty much. How should I go about making it so I can shift at higher rpm’s?
Was this the 29 lbs version that Ford Performance sells on their web site?The flywheel with a Ford Performance billet steel flywheel (SFI rated)
Red candy, does the MGW shifter give you any NVH?
This is the listing on FPP: FLYWHEEL LIGHTWEIGHT BILLET 8 BOLT MODULAR-COYOTEWas this the 29 lbs version that Ford Performance sells on their web site?
Ah OK...........so Ford does make a billet flywheel weighted close to the OEM nodular iron one (4.6L 6-bolt.... weighed 22 lbs....) but in 8-bolt pattern only.......? I was assuming that you'd got the FR billet 29 lb version........never saw this 1 so thanks for the info!This is the listing on FPP: FLYWHEEL LIGHTWEIGHT BILLET 8 BOLT MODULAR-COYOTE
I bought it about $100 cheaper from LMR: Ford Performance Flywheel
Advertised as 20lbs (9lbs lighter than stock)
