As mentioned several times on this thread, the fan assembly has most likely seen better days and is drawing way too much current to run, thus overheating the wires in the circuit. Repairing the wires is only part of the issue for what's going on with the fan. As mentioned, the Fan assembly needs to be replaced. You never mentioned how many miles the car has on it, but even if it's not a high number, the fan assembly wiring circuit on these S197s is very suspect and grossly undersized to handle the long-term current needs required to safely operate the fan assembly without some sort of inconvenient failure.
Having said that. If you have ensured the wiring from the fan connector all the way through the BEC (fuse Box) is intact, not overheated or even partially melted, then just buying a new standard fan assembly would fix your issue.
I would warn you that buying the 2013 FP SVT 7 Blade GT500 fan upgrade with your factory wiring would not be a good idea. The 12-gauge wiring in the circuit would be even more stressed with the current draw required to run that GT500 fan assembly. If you do shell out the cash for that FP SVT GT500 fan assembly, which flows about 37% more air than the standard fan assembly and it works great, then you really need to ensure wire integrity and install the wireeverything dual relay harness assembly. That harness uses 8-gauge wire and externalizes the amp draw and removes the BEC from the higher-amp circuit. Below are just some facts about this very common issue with these cars.
* I installed the 2013 FP SVT 7 Blade cooling fan on my GT500, plus installed that wireeverything dual relay harness assembly. It's the only way to go to bulletproof the S197 cooling system. I have also reset my Low and high Fan on/off settings to get more consistent and lower average engine temps. My low-speed fan comes on at 206, and my high-speed fan comes on at 216. My high-speed fan has never come on. The low-speed fan with the added CFM from the FP SVT 7 Blade 2013 fan assembly moves plenty of air to cool even in temps at 100+- degrees outside.
2013 FP 7 Blade GT500 Cooling fan.]
Wireeverything.com dual relay harness assembly.
Comparison stats.
The difference is the wire gauge amp ratings. You can see the S197 12-gauge wire in this circuit is very limited in capacity, thus the long-term melting issues.
