Can't get into gear
ZackRabold
Sacramento, CA
I've got a 08' Bullitt, for a while now I can tell the clutch and/or TOB has been on it's way out. Grinds into gears if I don't go smooth enough like the clutch wasn't disengaging correctly. Shifting from 2-3 with a little speed, but still being gentle with the shift itself, all of a sudden can't get into gear. Managed it what felt like halfway nto 4th to limp around the corner home and now can't get it into any when the car is running. No issues if its shut off, and if I try to start the car in gear it won't let me. At the time of it breaking the clutch pedal returned slowly once and since then zero issues with pedal feel, so I feel less likely for it to be a slave issue or something else hydraulic. There was a slight whine at the time too like a TOB-esque sound, that also quit after a minute or two. Idk enough about transmissions to feel confident diagnosing it off symptoms only, and don't want to have to drop the trans multiple times if I can avoid it-- any ideas?
whitmanink
denver pa
Welcome to the party....time for a complete clutch job . Time consuming job btw
i disagree,
with 4 , 6ton jack stands , and a trans jack ,
you disconcert the 02 sensors ,
drop the driveshaft .
unplug the one harness connector
remove all but 2 bolts to bellhousing,
place trans jack,
remove trans brace mount
secure trans to jack,
unbolt the two bellhousing bolts,
remove clutch line,
pull trans out ,,
and to change everything is soooo simple ..
i would recommend going to harbor freight and getting a hand vac to pump air out of the line when done,,
this saved me hours of hoping to get the clutch peddle feel back ..
and if you have a real lift , its even easier ,
whitmanink
denver pa
time consuming way would be to pull the engine out to do it instead
and also ,
i cannot say enough how much a remote clutch line res has helped to make the clutch stay consistent, and my brakes not fade,,
this is the one i got, )
(yes it works with our years too , as the 2010 is the same engine..
ive had this on for some time now and love it )
brasil
Germany
@whitmanink I am sorry to tell you that I had huge difficulties to remove the transmission .
First issue were two out of four nuts at the manifold to downpipe - there were rusted so badly at the and one of the studs was stripped.. had to renew the stud.
The came the moment when we tried to remove the transmission.. no space to pull the transmission far enough backwards to free the input shaft form touching the PP..
I /we used a lift... and perhaps I / we made a mistake while trying to pull the tranny.
Also pulling the Pedals assembly was a hard job.. but even worse was the reinstall of the assembly with the new bench bleeded master cylinder.
Midlife Crises
Fairbanks, Alaska
Before I even crawl under the car I have to remove the supercharger and intake manifold so the engine can tilt back enough to allow the tranny to clear the tunnel. That means removing the hood is the first step in dropping the transmission for me. Must be why Ford instructions say to drop the K member to pull the tranny. No need to remove the supercharger for clearance and you don’t leave the engine dangling from the motor mounts.
whitmanink
denver pa
i thought you were soppose to loosen the motor mount nuts so the engine drops at an angle to pull said tranny out?
Kev555
Ireland
I pulled the auto box on mine before removing the engine to overhaul it. I found it quite easy as with all RWD vehicles I've ever worked at but I also have a 2 post lift and a transmission jack which I could not have done the job without them. The auto box is one heavy ass bitch to handle on your own too, Id always tilt the engine to make it handy to remove bolts wiring etc on top of the box. I had to drop exhaust to remove engine anyways but I would do it that same way again as pipes running down each side of the box makes it very awkward.
brasil
Germany
@whitmanink. Loosen the motor mounts ?? The engine tills backwards even with the motor mounts in place / tightend . the angle of drop is limited from the firewall.
@ Kev555. Perhaps I made mistake - while pulling the Transmission ? I don´t know...
whitmanink
denver pa
yea im pretty sure lmr or one of them company's has videos on how to do things, and in one of them it shows puling the trans on the lift ,, i didnt see any issues ,
you never do in the videos but they didnt mention having problems like you have
the most ive heard was issues trying to disconnect the one plug on the trans thats it?
maybe the ford manual will say somthing?
MasterofDisaster
Michigan
and also ,
Bleeding the system might buy him some more time, and the remote reservoir would make it easier.
MrBhp
Mine just tilted enough to pull the transmission back and out. My biggest interference was the exhaust. (Singe turbo setup, 27 miles of piping)
Kev555
Ireland
its the luck of the draw, mine was a middle east car so there was no rust or seized bolts. the exhaust bolts were tight as you expect with years of heating/cooling but came off in on piece thankfully. the manual box going back together obviously needs a bit more due care and attention like using a clutch alignment tool to help centre the plates and all the other relative components need to be right.
whitmanink
denver pa
tbh ,, anytime you do anything with the headers or couplers,, in the exhaust,
its a given you will most likely fight them bolts and nuts out all the time,
unless its really really clean , or never drove in a garage
