We have a thread over on BossMustangsonline about fitting 11" wheels and larger 305, 315 tires at each corner. Wanting a set-up you can rotate keeps the Enkei 10.5" +38 the only choice for a larger wheel track combo while staying with a stock offset type strut. After thinking about it for a while I wrote the following:
Neema's idea of a +50 ET 11" wheel to use in conjunction with the Cortex offset struts gave me my latest idea. An ET44 11" wheel has about a 7.7" backspace. This will stick the 11" rear wheel out another .4" as compared to the ET55 wheel. That seems to be around the same amount of poke that the Enkei +38 ET wheels have, but with the extra inboard 1/2" of wheel width. In the front a 15mm H&R hubcentric wheel spacer could be used, like the one Blowfish Racing sells, to give an effective wheel backspace of 7.1" which should clear the strut. If my math is right that would be a feasible 11" rotatable wheel combo with a track usable front spacer and acceptable amount of rear poke. I think the rear tire should tuck in even better because its pulled inward a bit from the extra wheel width. Thoughts, opinions?
The only experience with wheel spacers has been the smaller stuff, about 1/4" just to keep a tire from rubbing, so if anyone has any feedback on using a larger spacer, either from the safety or durability standpoint I'd like the input.
