Finally got around to installing the new wheels & tires.
Front wheels are Race Star's 17" x 4.5" w/2.5" backspacing wrapped in M&H Tire's Racemaster 185/55R17s (26.0" in dia.). Notice the wheels easily clear the GT 500 front brakes using stick on weights.
Rear wheels are Race Star's 15" x 10" w/7.5" backspacing wrapped in M/T ET Street Radial 325/50R15s (28.0" in dia.). Notice the wheels easily clear the stock rear brakes using stick on weights.
Still needs to have the front end aligned after installation of the BMR K-Member and A-Arms, PCM reflashed due to the new tire size, and front struts (Tokico D-Specs) & rear shocks (QA1 single adjustable) adjusted.
For those of you asking, the front suspension has 1.25" drop and the rear has 1.0" drop via BMR's lowering springs.
Sorry I don't have any better pics of the entire vehicle, it is still on stands while I adjust the drive shaft angle for the new Axle Exchange 4" aluminum one piece drive shaft.
PS: just a word of caution. Before installing the center caps on the wheels I suggest running a 6 x 1.0mm tap through all the mounting holes
