2005+ Rear Gear Oil
NUTCASE
I am making this so that hopefully it is an easily searchable thread for anyone who does not want to do all the searching and research I went through.
To use friction modifier or not to.
This can get confusing because I myself have not kept up with the changes in technology on this and there is a LOT of conflicting information between chiltons manual, ford specs, lube advertising, and what can be found on google.
Bottom line up front: for 2005+ cars 75w140. If it has friction modifier in it you don't need to add any. It actually is possible to use 75w90 but then you have to use friction modifier. Also 75w140 is reverse compatible with earlier mustangs that have trak loc.
I am referring specifically to Trak loc axels. If you have an eaton or a whatever contact whoever made your diff.
All the major brands of 75w140 have the correct additives in it already with only one exception that I could find which was Motorcraft. However always read the label because I will not be held responsible for you buying some off brand like Super Tech and assuming things.
By major brands I mean RP, Amsoil, Lucas, Moble 1, ect. But still read all labels first.
If you feel as though you have net been bent over enough today you can go to a ford dealership and buy Motorcraft which is more expensive than Royal Purple and then also have to buy the friction modifier on top of it.
This is the reason why in Ford publications it says to add a separate bottle of friction modifier. Chiltons bases what they publicate off of what Ford tells them the car needs so that is why chiltons also says specifically to add a separate bottle of friction modifier.
Why is 75w140 reverse compatible? The numbers refer to the measured oil weight as in its thickness alone. However 75w140 is synthetic and 75w90 is conventional. The chemical makeup of synthetic gear oil is completely different than that of conventional and though the oil weight measurement is different the 75w140 is plenty slick. The conditions in your rear axle are not like the conditions of your motor or auto trans where the thickness of the oil alone can make a huge difference.
Something to know about friction modifier: It makes your lube more SLICK, it does NOT add friction. One of the old problems with LSDs is that they make all these noises and shudder effects when going around a turn. This is because of the friction between the clutches when one wheel is going faster than the other around a corner. 75w90 conventional and lubes like it are not slick enough to allow the clutches to work the way they are supposed to. Friction modifier balances this out. One would imagine then if you add friction modifier to a lube that has the additive built in you would loose some of your trac loc function. However I have not found anyone using a synth with a modifier complaining about this.
This is also why some people experience chatter or hear a moaning sound coming from the rear when they use 75w90.
As far as fill amount both Ford and chiltons say 4.25 pints. This is to account for 4 oz friction modifier. Therefore the actual fill capacity for using 75w140 with a built in additive is 4.5 pints. Most gear and diff cover kits come with 4 pints (2 quart bottles). I only imagine this is because of the availability of containers and you are better off a half pint less then 1.5 pints over.
If you think the .5 pint is a big deal try this. Get a pitcher and put 2 quarts in it. Then get a measuring cup and add a half pint. Look at the difference, its not a bid deal is it?
However that being said I ordered 3 bottles and will be filling mine to spec. I got some Lucas 75w140 from Jegs $11.99 per bottle free shipping.
If you don't already have a favorite brand throw darts at a board. All the major brands are good. This is not F1 racing and you are not going to win any more races because the brand of gear oil you picked gave you a .002 sec advantage. Besides without F1 level equipment I doubt you would be able to scientifically prove one over the other.
This information was gathered between quotes from a Ford rep, and LOTS, and I mean LOTS of separating the wheat from the chaff in online searching and reading publications.
I hope this helps somebody and if somebody has information they would like to add or perhaps can prove me wrong on something go for it.
skwerl
tree hugger
central Florida
Lucas is also available at most big chain auto parts stores instead of having to order it online. I've been running Lucas with my Eaton TrueTrac for quite a while now and it works perfectly.
Your comments seem to be stock rear diff only, correct?
Gray Ghost GT
Road Racing Fanatic!
Madison, AL
I always refer to the manual that comes with the differential I'm using, which can vary based on fluid weight and LSD additive requirements, e.g., OEM vs. Eaton Truetrac vs. Torsen T2R.
+1 for Redline and Amsoil.
Riptide
Will work for Mustang.
Montucky
+1 for not adding modifier if the oil you use has additives already. That caused a problem for me.
Sent from my iPhone using Tapatwat
Greg Hazlett
Stepping on the Pink Bus
Chesapeake, VA
Very true; I can't speak for the other oils but Amsoil specifically states you need to use the friction modifier as their rear end oil does not have it.
TexasBlownV8
Formerly TexasBlownV6
Central Texas
Interesting info on the friction modifier. I usually add it if I know the specific lube needs it or if the rear end starts groaning on low-speed turns after a fluid change or after a rebuild. Using RP, I ran into that, and had to add friction modifier to prevent it from happening. Now I'm not sure that was good to do, on a race car. But it did stop the low-speed turning groans.
05gtowner
So. Cal
As a former Amsoil jobber I can tell you half of the hype on Amsoil is just that. I would never run gear oil for the 100K service interval they recommend for their severe gear. http://www.amsoil.com/shop/by-product/gear-lube/severe-gear-75w-140/?code=SVOQT-EA
The most I would run it for is 50K at the most. Amsoil products work well for the most part but a lot of it is just snake oil mythology. I know I used to sell it. Just use a quality gear oil and change it regularly and you won't run into issues.
quiksilver15
Houston
My installer recommended for me to buy 80w-90 non-synthetic Lucas with a FM for the factory diff and Ford Racing 4.10s. He said it's my choice, but that is his recommendation.
What is y'all's take on non-synthetic and the factory diff?
wckdgt
trenton, ohio
mine says synthetic only on the diff cover
NUTCASE
if you read through my thing you will find I commented on 75w90. It can be used with a friction modifier in the newer diff. Some guys recommend it because its what they have been doing for years, and some people feel that if something works why change it.
and as far as 80w90 or 75w90 there was some information I left out on that to keep my post on track. 80w90 can be used in place of 75w90. 75w90 comes from the factory because the car has to be expected to perform to a certain standard in all climates, to include places like Alaska and northern Russia. The first number represents the oils cold weight and 75 works better than 80 if you like in like -40* weather.
quiksilver15
Houston
Thanks nutcase. I believe ford uses synthetic for better gas mileage, most aftermarket LSD recommend Dino 80w-90. I've read Dino is supposed to make the clutches grab better. I think I will go ahead with his recommendation and go with good ol' Dino. Lucas 80w-90 with a Ford FM.
sgt slaughter
When changing out gears, is there a break in period where you have to change out fluid after say 500 miles?
If that is the case, should I run a good (but less expensive brand) fluid and then switch to small?
