2006 mustang gt cranks but wont start
amatthews442
Jerseyville Illinois
So far I've replaced the:
Spark plugs/coils
Cam sensors and crank sensor
Battery
All cylinders were in the low 180s range
I've checked spark using an inline tester
And I used an obd2 scanner to check fuel pressure which shows 43-44 with KOEO and about 70 when cranking
I've also tried starter fluid (per online mechanics suggestion)
The only time I ever got it to start was after replacing all ignition coils and it ran perfectly for about 15 minutes but once I shut it off, it once again wouldn't start.
Any help would be appreciated
Since it just won't fire, you lost sprark or fuel. Crank it for about 10 seconds, pull a spark plug out. Is it wet with fuel or dry as a bone?
amatthews442
I won't be able to do it precisely that way until tomorrow but from the many times I've pulled he plugs after failed cranks lately. The seem to come out wet with fule and soot
JC SSP
FL
I have to ask… did you replace all parts with Ford Motorcraft replacement?
Also any codes?
