Roush fun
I want a set of those stock wheels for my roush, dont suppose your selling any. The previous owner of my car put saleen wheels on it and i couldnt leave them.
"Track day went without issues. I did install a big blower pulley to reduce boost; ended up with 10 PSI. My street/drag pulley makes 14 PSI.
On the road course, I hit IATs of 175* on decel. Man I never realized how hot things got on the road course."
175 deg F IATs on deceleration ! WTF happened there ? Per lingenfelter, your
mezziere 20/55 gpm pump is not doing much in the way of gpm...maybe 5/6 gpm at most.
Heck, your iat is sky high...and that's with 10 psi boost. Does anybody know what pump is used on the 13/14 GT-500 ? That might do the job better..or 2 of em in series. Perhaps run any IC pump on 17vdc. (Those mezziere pumps are supposed to run on 16vdc). One of those unregulated 12-14 vdc in..and a constant regulated 17 vdc output dc-dc converters might do the trick. BAP etc.
What else that might just work is a fead driven IC water pump. Then you have some hp to drive it at least. Flip side is gpm would rise+ fall with rpm. Ok, how did ur rear axle end up askew? I can't see how ur car would even stay straight. I checked my 2010..with 285-40-18's..and gap is identical on both sides.
LOL...
Jimbo, 175* IAT at decel is quite normal on a road course... Once I gave it throttle input, my IAT instantly dropped to the 140 range and 130s at WOT. But as soon as that throttle body closed, the IATs jumped to 175*s...
20 mins of continuous WOT, 2000 plus degrees generated by brakes, etc...the whole car becomes a hot potato.
In comparison, when I was drag racing for two days straight, my IATs were in the low 130s in the staging lines and dropped to high teens when going WOT.
Track days are the most brutal thing you can expose your car too... Nothing compares.
I spoke to Justin a while back and he did suggest I get rid of the Meziere pump and go with a 2013-2014 GT500 coolant pump; that it flowed around 8 or so GPM. He claimed the Meziere did not flow the "claimed" 20 gpm...that it may even flow less than the 2013-2014 GT500 pump.
Regarding the axle, measure hub to hub. I guarantee you that your axle will be at least 0.25" off side to side unless you have adjustable LCAs. My neighbor checked his (bone stock 2006) and its 0.50" off. All S197s have this issue.
Its not noticeable with near stock sized wheels/tires.
Has anyone tested that pump?
My non scientific data by looking inside the tank is that it flows a LOT more than the Bosch pump. It's a $230 pump directly from Ford parts.
Gerald, are you using a glycol-distilled water mix in your IC loop ? 100% distilled water + water wetter (for summer time) on paper, should be far more effective at extracting heat inside the IC.
Inline.^ fully submerged pumps?
I think the rule 2000s are the submerged pump and o have seen them used tooO.k. I was thinking of the rule pumps.
I run the 2013 GT500 pump and it's like a hurricane in the degas. Pretty awesome. IAT's are 112 cruising at 80 degrees, less when I'm hammering on it. Worse 140 after heat soaking parked, but quickly drop after a block of when driving, into the 120's. I'm using the large Roush single pass front hot side rad. Unless I've parked the car the intercooler water is always cool to the touch.
Looking at water/meth next year because the 91 fuel here is causing grief at 8.5 psi, IMO. Might install nozzles right into the lower intake, after the blower outlet.
