blownGTvert
Add the 13/14 GT500 exchanger to go with the pump! It's a monster at 4" thick!
As for water/meth, I was going to drill and tap the intake itself. I haven't looked lately but it seems to me I could go just under the blower mounting surface, with a pair of nozzles spraying out into the opening over top of the heat exchanger. The spacer plates for carb apps have the meth nozzles flush with the inside of the spacer. This is not a heavily loaded area, I don't think drilling the casting would have any negative effects on its structure, especially a 1/4 hole at worst. There is no water back there, afaik.
Is it bigger than the dual fan VMP unit?
What blower setup do you have? With the ROUSH manifold, there is not enough material and space/clearance. Ideally you want the spray to be upstream enough to vaporize and absorb heat. If you inject too close to the heads, you'll be spraying straight liquid possibly pooling in areas and not getting even coverage across the cylinders.
Just some thoughts...
People have sprayed meth into the manifold after the intercooler core. It's only a 1/8 npt sized hole at worst. Looking at pictures of the M90 manifold there appears to be space, I'm more concerned about getting the fittings/line on the outside near the fuel rails.
Think of how clean that oily cruddy lower intake will get!! :-s
What would you have to do to tune for meth? I would think you would just need to adjust A/F at WOT, right? It won't be distributed to each cylinder equally so you would want to be conservative. Keep timing controlled by knock sensors and IAT.
Not sure about this application, BUT I can give some data on my old 2004 Cobra - and current 2015 with TVS.
It would cruise at 125 IAT2s....and get to 165-170 on a full 1-4 gear pull, then drop back down to 130ish..... This was on an 85 degree day with 21psi boost.
That was with the stock Bosch IC Pump, and an Afco Dual Pass H/E (for 03/04 Cobra)
I upgraded the lines, fittings, and went with the Jabsco pump pictured above, and a GT500 specific Afco H/E (much larger) and the temps went to 110-115 cruising, and 135-140 after 1-4 pull.
My current TVS Coyote....I have 115 cruising, and 120 WOT after a pull. Also on 85! degree day. This is on 15psi making 800 - and it's an Afco with fans, and 13/14GT500 Pump. Recovery time is also VERY quick.
Blower discharge temps of 220F would be required to boil coolant. Is this reasonable to expect? I like reading about the Terminators and 150F IAT's - people made it work just fine back then. Now we're dealing with some kind of monster if you're over 120.
Wish we had E85 here, even if it does kill the environment. Justin was making super wacky power on Brian's car running Torco. Nobody knows those IAT's.
The IAT's are materially the same between the M90 and the TVS 1.9 @ the boost levels Jim was thinking of running.
I was talking about straight water or 20% glycol at best boiling in the heat exchanger. I would like to know something about blower discharge temps, and the only way to find out is probably by installing a probe and measuring myself.
I would not worry about boiling the supercharger coolant. You have to be doing something really wrong to make that happen.
