I thought you were using the GT500 pump and pickup that come with the pan. I didn't realize you already had an older version.
I'm skeptical. It seems that they keep finding things. I hope it turns out good for you. BTW I'm always skeptical.
I agree, I've been skeptical too... But you have to trust the shop you're working with too at some point or else whats the point.
I think they will keep finding things until they find the bottom of Gerald's wallet.
Skwerl,
!!?? lol
Yeah, I was feeling that way too.
I don't think the shop is one to take advantage of customers otherwise they would not have the reputation they currently have.
I believe they are are on the extreme side as far as machine shops are concerned, in the sense that most shops would not have checked FRPP's valve job and assumed it was right.
In my case, its a good thing this shop is highly detailed seeing my luck thus far. The shop does not let anything slide as at the end, its their reputation and they can not afford to assume something is done right.
Its surprising and scarey to think that the products put out by FRPP and other big names is not put to par on quality.
The shop owner, Chuck, has told me that performance engine parts (heads, blocks, etc) are not bolt-on ready as most think they are.
Sure they will work and make the power, but they will leave a lot to be desired and potential.
Like Chuck says, when you buy performance heads and what have you from a big manufacturer, you're paying for the engineering that designed that part. You are not paying for the detail (machine finishing) work. Remember, the guy finishing off those heads is a poor low wage worker making ends meat. You think he will put the effort into those heads???
Now I see why JDM's version of the FRPP head are so much more expensive...
