2010 mustang gt 4.6 3v manual
Neek
Georigia
My transmission will grind when shifting into 3rd normal driving condition and double clutching. When I try to go thru the gears from a stoped position with clutch all the way down will shift thru all gears no grind. When I try with no foot on clutch it will lock out all other gears but not 3rd is this a synchro issue or clutch issue
Midlife Crises
Fairbanks, Alaska
Yes. Your 3rd gear blocker ring is not working. It is part of the three piece synchro used in the 3650 five speed. A warn clutch or a clutch that drags can amplify synchro problems and often effects getting it into gear from a stop.
Note that that little grinding will damage 3rd gear and the 3rd/4th slider if you continue to drive it.
Neek
Georigia
If I drive it for now until I can save up the money to get it repaired. I noticed while driving I go from 2nd to 4th no grinding could that damage it any more then it already is
MrBhp
No it will not. And that's a good plan.
My Dodge truck has a bad 3rd gear syncro. I don't use the clutch when shifting, just get the rpm's right and it goes in smoothly. I can't go thru the gears quickly, it only works for leisurely driving.
86GT351
Sunny South Florida
As long as you don't go to 3rd. When you have a syncro problem the teeth get flattened or mushroomed. If you continue to try and use 3rd it can make the damage worse.
