UPRGabby
S197 ***** Sponsor!
UPR is one of the first to market with the Upper Control Arm & Mount for the 2011 5.0 Mustang!
3 Kits Available:
2011 Mustang Pro Street Upper & Upper Control Arm Mount
Retail Price: $239.99 S197 Member Price: $215.99
Strengthen the weak point in your 2011 Ford Mustang GT's rear suspension with this all new Upper Control Arm Mount and Pro Street Non Adjustable Upper Control Arm. Complete bolt in installation that replaces the flimsy factory upper mount and control arm. This new unit will eliminate any flex, which means more power to the ground. Also includes two separate mounting outs for more adjustability for better traction and handling. Control arm features energy suspension bushings and out unique large inner bushing sleeve. Click here to read more.
2011 Mustang Pro Street Double Adj Upper & Upper Mount
Retail Price: $269.99 S197 Member Price: $242.99
Bullet proof your rear suspension with UPR Products Pro Series Double Adjustable Upper Control Arm and Upper Control Arm 3rd Link Mount for your 2011 Ford Mustang. Our double adjustable control arm allows for quick and easy adjustments for dialing in your pinion angle and suspension so you get the power to the ground. From our 1/4" Steel U Bracket and Gussett to our 1/4" thick Tube End with Energy Suspension Urethane bushings. Click here to read more.
2011 Mustang Pro Series Double Adj Upper Arm & Upper Mount
Bullet proof your rear suspension with UPR Products Pro Series Double Adjustable Upper Control Arm and Upper Control Arm 3rd Link Mount for your 2011 Ford Mustang. Our double adjustable control arm allows for quick and easy adjustments for dialing in your pinion angle and suspension so you get the power to the ground. From our 1/4" Steel U Bracket and Gussett to our Chrome Moly 7/8" heim joint that has 33% higher load capacity compared to our nearest competitors supposed competition upper arm. Click here to read more.
