2011 Mustang Pro Street & Pro Series Upper Control Arms & Mounts
UPRGabby
S197 ***** Sponsor!
Lake Worth, FL
UPR is one of the first to market with the Upper Control Arm & Mount for the 2011 5.0 Mustang!
3 Kits Available:
2011 Mustang Pro Street Upper & Upper Control Arm Mount
Retail Price: $239.99 S197 Member Price: $215.99
Strengthen the weak point in your 2011 Ford Mustang GT's rear suspension with this all new Upper Control Arm Mount and Pro Street Non Adjustable Upper Control Arm. Complete bolt in installation that replaces the flimsy factory upper mount and control arm. This new unit will eliminate any flex, which means more power to the ground. Also includes two separate mounting outs for more adjustability for better traction and handling. Control arm features energy suspension bushings and out unique large inner bushing sleeve. Click here to read more.
2011 Mustang Pro Street Double Adj Upper & Upper Mount
Retail Price: $269.99 S197 Member Price: $242.99
Bullet proof your rear suspension with UPR Products Pro Series Double Adjustable Upper Control Arm and Upper Control Arm 3rd Link Mount for your 2011 Ford Mustang. Our double adjustable control arm allows for quick and easy adjustments for dialing in your pinion angle and suspension so you get the power to the ground. From our 1/4" Steel U Bracket and Gussett to our 1/4" thick Tube End with Energy Suspension Urethane bushings. Click here to read more.
2011 Mustang Pro Series Double Adj Upper Arm & Upper Mount
Bullet proof your rear suspension with UPR Products Pro Series Double Adjustable Upper Control Arm and Upper Control Arm 3rd Link Mount for your 2011 Ford Mustang. Our double adjustable control arm allows for quick and easy adjustments for dialing in your pinion angle and suspension so you get the power to the ground. From our 1/4" Steel U Bracket and Gussett to our Chrome Moly 7/8" heim joint that has 33% higher load capacity compared to our nearest competitors supposed competition upper arm. Click here to read more.
UPRGabby
S197 ***** Sponsor!
Lake Worth, FL
Yes they did for this part. We were surprised too!
The bolt that holds the upper to the mount is much larger. Also the bolt that comes from the inside of the car is larger as well. UPR PRODUCTS sells this as a complete kit. We have picked up almost 2 tenths in the 1/4 mile from the suspension install. Not bad for a little more than an hours work.
luillo
Fort Walton Beach, Florida
basically the Upper Control Arm bolt the attaches to the UCA Bracket is bigger??
And the UCA Bracket bolts are bigger too??? So there is no way to use and old style UCA with a new UCA Bracket????
UPRGabby
S197 ***** Sponsor!
Lake Worth, FL
The 2011 uses a larger bolt where it attaches to the factory bracket. The factory bracket also uses a larger bolt where it attaches to the vehicle, specifically the bolt that is located under the back seat.
UPR provides you with a new-stronger bracket and a new control arm with all of the hardware needed to do the install.
