Full_Tilt
- Joined
- Jan 20, 2011
- Posts
- 1,697
- Reaction score
- 1
Im glad some guys here are taking the step on buying this early to test it out. The boss, i feel, is not making substantial power with this intake manifold (MAYBE 12 hp) and that the real numbers over the base 5.0 motor is the cams on the exhaust side. sure the intake helps if ou are squezing every drop out, but i hope everyones not diapointed with sub par results incase. trial and errot i guess. the only thin i see this intake helping with is because the RPM is raised on the BOSS and its needed for the 7500 limit vs our 7000 limit, as in we are not making an more power past that point and this intake will help slightly with that. We will see soon enough i guess...
Apparently the revised exhaust cam is only a very mild change. No lift increase, just a little more duration.
I expect the IM is the real power maker.
