Aandf1978
M90 SUPPORTER!!
Got an extra 8mm hex head socket? I seem to have lost mine!
I think all the turbo install bugs are worked out! Replaced the broken radiator drain plug, broken horn and lower radiator hose that was cut too short and kept blowing off the adapter; I could not access the oil fill cap on the passenger side VC with the way the water hose was routed but a 90" swivel fitting cured that. Started the car, let it come to temp and no leaks!
The test of the AC line will come when I have the system charged...fingers crossed.
It sucks to drive around all day with no ac. My NEW work truck's ac is broken and its been in the shop 4 times all for ac work. It just keeps getting worse and worse. So after 12-15 hours a day with no ac working in the sun i have no energy for anything else.
