Since all my stuff just arrived, I thought this might be useful info for people who want details on the complete kit from LRS.
Here's a copy/paste from my build thread:
Soooo, Latemodel Restoration Supply (LRS) put the '13 Shelby GT500 brakes on sale, and I couldn't help myself...
When the new Shelby Brakes came out, the cheapest you could get them was through Tousley Ford, who had the fronts for about $1285 (if you knew all the part numbers) and the rears for about $525, so it was about $1810 plus shipping. When Latemodel Restoration first put them up for sale as a complete kit (fronts and rears) they were $2299. I was ready to buy them from Tousley, but decided to wait a little bit because I didn't want to shell out the coin.
Then, a couple weeks later, LRS dropped the price to $1699 for the whole kit, which is a ridiculous price for this setup. As of today, the price has already increased to $1895, so I defnitely "got while the gettin' was good."I ordered them on Thursday, June 13th along with all the stuff I needed for install. (like diff fluid, brake fluid, gaskets, etc) To make things even better, I used a 5% off coupon, so the total order (including all that extra stuff) was $1695.71 SHIPPED. :mrgreen:
Here's the breakdown:
- (2) Bottles Motorcraft Brake Fluid - $14.99
- (2) Bottles Royal Purple 75w90 Gear Oil, plus Motorcraft Friction Modifier - $44.99
- (1) Lube Locker 8.8 Rear Diff Gasket - $24.99
- (1) Ford M-2300-T Brake Kit - $1699.99
- 5% Discount Coupon (minus $89.25)
- Total = $1695.71
The brake fluid, diff fluid, and gasket all arrived prompty on Wednesday, June 19th. They are shipped by LRS. The brake kit is shipped via a freight company directly from Ford, and obviously takes a little longer. After a little delay because "the truck driver had exceeded his daily DOT hour limit" I got the brakes today, the 22nd. They were supposed to arrive yesterday. Anyway, I'm excited as hell, so here's all the stuff.
Here's the big ol' box that it comes in, on a pallet. This box is HEAVY.
Lots of stuff inside there:
Here's all the stuff in the crate plus all the fluids I got earlier from LRS.
Another shot:
Dust Shields, brake lines, front rotor boxes, brake fluid and friction modifier:
Boxes full of calipers and anchors:
Diff fluid, new bolts, front brake lines, rear rotor boxes:
Front rotors. These things are shockingly large in person. (and freaking heavy!) It's nice that they're coated both around the center of the hat, and on the edges where the vanes are. They won't rust like crazy and look ugly.
15" and 32 pounds. Each.
Rears are 13.75" and XX pounds.
Boo yah. Front and rear calipers, and rear anchor brackets. I need to paint or powdercoat those rear anchors so they don't rust and look like crap. It looks like there was a little bit of moisture in the box, because one of the anchors already had a little rust on it.
Again - pictures don't do these things justice. They are so freaking huge.
Quick-change pads. Just pull the pins. Pretty cool.
Made it Italy, just for FoMoCo.
An attempt to show how big these calipers are:
Here's the whole front setup:
As a public service, I weighed everything so everyone knows what kind of weight they're adding when putting these things on. I'll also weigh all my old stuff when I pull it off. I used my bathroom scale, so these numbers are obviously just approximate.
- Front Rotors: 31.6 lbs, each
- Rear Rotors: 15.8 lbs, each
- Front Calipers: 16.6 lbs, with pads, each
- Rear Calipers 9.4 lbs, with pads, each
- Rear Anchors 5.0 lbs, each
- TOTAL WEIGHT: 156.8 Pounds
I suspect these will be substantially heavier than the stuff that comes off. Now I need to get a hold of some paint, sandpaper, brembo stencils, and prep stuff. I want to paint these 2000 Ford Mustang Sunburst Gold, with black lettering, and high-gloss clear. I might also buy a GT500 rear diff cover since I have to open the diff and pull the axles anyway. I might install a GT500 rear diff cover too, and an adjustable panhard bar since I have to pull mine off for the install. That would get my axle centered in the chassis, which would be nice. Finally, I need to ge those rear anchors powdercoated black - I might just do that myself in the garage since they're already pretty close to being ready for coating - just a little light blasting to take the rust off.
Either way, I'm really excited about this. I'm pretty confident you can't get this much braking power at a better price anywhere. This will ensure I can always stop safely in the grocery store parking lot, and impress the ricers with wheels the size of my brakes.![]()
More to come on this project later...
Paul.
