Edit: Tires are sold. Wheels will go in another thread.
The tires are in great shape. I bought them as lightly used. Since mounting I've put about 100 miles on them. No passes or burnouts while I've had them. The previous owner said they had under 10 passes. They drive nice at highway speeds, no wandering.
Tread depth is measured at .145"-.155". This is just a hair under 5/32" (.156"). There is lots of use left in these tires.
Tires are mounted on Summit Warrior R/T 15x8 wheels with a 5x4.5 lug pattern. Back space is 5.5". They stick out a little on my 2008. About the same as my 15x8 Racestar wheels do. My car required caliper grinding to get the wheels to fit. Others have reported they didn't need to grind. Ford has used more than one caliper supplier so it's luck of the draw. If you look closely you can see where there was light caliper contact on one wheel.
The wheels also have band type tpms sensors mounted on them. Edit: These wheels take a 60 degree conical lug, same as stock.
Part number for the wheels is: SUM-571-5866PS Link to summit site http://www.summitracing.com/parts/sum-571-5866ps/overview/
These are expensive to ship. I'd like to find a local sale but will ship. The last time I shipped a setup like this it cost $130. I'll cover anything over $120 and will charge a flat rate of $120 for shipping. If it's less I will refund the difference.
Price is $425 without shipping for wheels, tires, tpms sensors, mounted and balanced.
