298....tr6060.....67mm@20 psi.....in progress!
one eyed willy
Pizzle fo shizzle
Lakeland FL
yeah,welding looks like shit compared to some real good welders......but i know its solid as hell, checked for all the pinholes and welded those up as well......should be a real solid set up!
3" piping from the headers to the turbo and from the turbo to where it y's into the dual exhaust. most kits are 2.5" from the headers to the turbo.....my intensions are to releave as much heat off the cylinders as possible.....and reduce as much back pressure between the headers and turbo.....this turbo spools planty fast so i dont think ill have issues with loosing any pressure there!
Chris06GT
Dragging LS A..
Alabama
Awesome work my man!! We'll have to post pics of fab work in Pics and videos. I have a bunch of pics I'll get from my buddy.
GrnBullitt08
Dale Jr
Northwest Indiana
All the fab work looks good. Tig welding is the way to go if you know how. But once you get everything coated it wont really matter. Nice work.
one eyed willy
Pizzle fo shizzle
Lakeland FL
job i was suppose to go on today got cancelled....so i came home and got to work, most productive day so far!
radiator installed and re-painted the behind grill area
all re-wiring for headlights complete
headlights installed
all vacuum lines re-routed
all sensors for the aeroforce gauges re-wired, oil temp,oil pressure and electronic boost gauge
meth controller installed and wired up
wiper cowl and wipers re-installed
made fuel line that replaces the entire fual line in the engine bay
now, for those who would like to install OEM HID's on thier non-OEM HID car.....this can be done with a few modification to the factory harness, adding 2 relays and a diode.....and also modifing the plug, the non-HID plug does not plug into the HID housings, they are slightly different. gave the car power today for the first time in 4 months to test out the headlights!
Id like to thank TJ for the lights! they took some work to get them looking good but they look great now!
whats left:
buy TR6060...have a lead on one
buy clutch
pick up and install turbo pipes
send off turbo for inspection and possibly rebuilt
modify valve covers
powder coat valve covers
powder coat C&L intake manifold
install engine and tranny
cut down aluminum driveshaft and rebalance
buy and install breather cans
install rear meth tank and pump
install LED's for meth and low level
TUNE!!!
WASH!!!!!
one eyed willy
Pizzle fo shizzle
Lakeland FL
tr6060 aquired
valve cover and piping back from welding and ceramic coating, just need to clean up the valve covers and take them for powder coating.
GB10
8s coming soon?
Burleson, TX
Looking real good. I bet welding those bungs on the valve covers was a pain, but definitely a good idea.
NUTCASE
Subscribed
excellent work
I gotta get me a welder and build up some skills
one eyed willy
Pizzle fo shizzle
Lakeland FL
clutch installed!
motor installed!
fixin to polish up the input shaft on the tranny and should have that installed in a few minutes depending on how much it fights me!
one eyed willy
Pizzle fo shizzle
Lakeland FL
tr6060 is in and TOB hooked up.
i will have to get my driveshaft cut down, it measures 53" from flange to flange and my driveshaft is 53" when its fully compressed.....ill drop it off tomorrow to get cut and rebalanced!
dropped the intake manifold off to get some airbrush work done!
BruceH
BBB Big Bore Boss 322
You are getting close. How did you like not having to deal with those stupid ears on the 3650? Makes quite a difference imo.
one eyed willy
Pizzle fo shizzle
Lakeland FL
it wasnt too bad....it was still a pretty big chore on my back, using 2 jacks and balancing every damn thing,lol....
