3 #8's at one east coast dealership.
BAKnBLK2010
Harley Davidson FLHTCI
Sandy Hook Kentucky
Here's the scoop...
My service manager is off today, so I called Springfield Ford myself. After going through a couple different people I was directed to the person who handles "heavy engine repair". I spoke to Danny in service at Springfield Ford. They currently have no Mustangs in for any sort of engine repair. One month ago they did replace a motor in a 5.0L. He pulled up the repair order and gave me details on it. That particular vehicle was a rental car. It came in for a random misfire. They could never pinpoint the specific cylinder. Compression and leak down tests came back good. PCM tests showed unaltered. After replacing all spark plugs, all injectors, and the fuel rail the misfire was still present. Tech hotline recommended and approved an engine replacement. A new crate motor from Ford was installed, problem solved and vehicle sent on its way.
That is the ONLY Mustang they've had for any sort of engine related concerns.
I think that settles that.
Thanks for calling!! :clap:
Bodam
Houston
Jesus, does the #8 problem even exist? I'm tired of hearing about it.
Riptide
Will work for Mustang.
Montucky
So the whole story is BS then. Nice!
Time to lock thread?
Sent from my iPhone using Tapatwat
Mach2burnout
05 Redfire GT
Central Louisiana
It would be very cool if someone in that area would go by that dealer and confirm this. I'm not saying you're lying popeye, so please don't take it that way. I appreciate your passing along the info. However, it would really help to add some legitimacy to this thread.
^^^^^^^^^^10X
gil_t2
Love Nitro in the Morning
Northern Va
You guys are increadible,,,The tuner in question hates these forums and all the BS on them. I didn't want to flip his name out there. This is confirmed and there is an issue with #8.
Popeye, not calling you a lier.
If you have been following this #8 problem, you know how much crap has been spread! The first people to claim this said there cars were stock and bitched about Ford. All were found to be lier's!!!! They were running 10's in the 1/4, and blew them at the track. WE found there post ,and videos before they deleted them. We now know there is an oil problem too. Dealership i am at has had only 1 blown 5.0, and it was because of the owner installing a S/C the day after he bought it. And he F**it up. BTW we have 2 locations and sell a lot of Mustangs. WE just want solid info, and if Ford is keeping this Hush Hush, why is an aftermarket tuner involved?
2006torquefreak
Mcdonough, Ga
Here's the scoop...
Edit: For anyone wondering, he said it was an automatic, as it should be for a rental car.
:highfive:
Thanks for digging for accurate info.
19COBRA93
Ford Racing
Clinton, Ut
Yeah Popeye, we're in no way blaiming you for this. I personally think through word of mouth, the engine replacement they did have turned into several and people started to hear what they wanted to hear instead of what actually happened.
It's no different than the "wisper game".
19COBRA93
Ford Racing
Clinton, Ut
The tuners really want this to be a Ford problem, but I really don't think it is.
Even if it was Lund, there's the possibility he was simply given bad information from somone else.
Scott_0
OxFORD, Pa
I agree to an extent, in stock form they are 100% fine but with a tune that may be off, or some tool running 87 or 89 with an aggressive 93 tune they are a grenade. seems they are a bit limp wristed and Ford knows this, you would think if they are detonating that bad they would blow a head gasket rather than eat the piston....
Sky Render
Stig's Retarded Cousin
NW of Baltimore, MD
This ^^^
Thank you, thank you, THANK YOU for checking on this.
I say we lock this thread before more crappy information gets spread. :deadhorse:
19COBRA93
Ford Racing
Clinton, Ut
I also agree. I think that cylinder is a hot spot by design. While it works for stock cars, slightly modded cars might be on the egde. I'm still of the opinion some sort of cooling mod may clear this up.
And these motors, modulars included, don't generally blow head gaskets. I've melted down a few pistons and haven't had any gasket failures. They're actually really good gaskets and have good clamping force.
SilentScope
Chemist by profession
South Florida
