324 big bore long block, novi 2200sl,injectors,gauges
ScootDawg
Lake Charles La
i bought this motor from abdulla a year a go and never finished the build already have a stock motor so i will not trade for a stock motor asking $5500 obo+paypal rather not ship also have a spec 3 clutch to throw in also if wanted
built by Mike of Modular performance prior to him passing away.
The Long block was assembled using all new chains, guides, springs, retainers, lash adjusters, seals, etc. I have receipts for the motor as well.
Specs on the motor:
324 Cubic Inch FRPP Boss 5.0 modular (5.4L)
Kellogg 3.75 stroke crank
Diamond custom 17cc stroker pistons 9.4:1*
Upgraded Piston H13 pins at .927 dia
Total seal SS ring set
Oliver billet "I" beam stroker rods @ .927”
HP 153 coated main bearings
King 7065 coated rod bearings
ARP 156-5401 main studs
Rear seal
Block was decked with hone plates
Ceramic coat piston tops
Dry film coat piston sides
Comp 127350 Stage II Blower cams
Comp Valve springs/Retainers
New 2008 Style heads
exedy light weight 8 bolt flywheel
TSS Billet Geared Oil pump
60lb ford racing injectors 0 miles $300 shipped
I'm confused by your comment about post -08 heads. Is this using 3v or 4v heads? And does it take a 3v or 4v intake manifold? Will it run with the 05-09 computer or do you need a Coyote computer to run it?
VistaVert1983
Short Throw King
So all you need is the 3v harness, intake manifold and you're good to go?
2NY
icedesign
oak lawn, IL
Im interested in the intercooler if you want to part it out. Let me know how much shipped? Also, is the wideband have everything included ready for install?
degmidget
U have the intercooler sold on here and I want the head unit lets make a deal!
AbdullaGT500
Little Rock, AR
It is a 3V motor. Stock 3V deck height, which means its a direct replacement for a 3V motor. Stock wiring harness, stock intake/exhaust manifolds bolt right up.
Yes.
Stock 3v heads? Any port work?
They are stock 08+ New style heads. Not ported. They were new take offs from a crate motor.
Guys, this engine is an absolute beast and a direct swap for a 3v motor. I have videos of it running from before I sold it to him if anyone would like to hear it. If anyone has any questions about it feel free to PM me.
ARP head studs or TTY bolts? I see ARP main studs but nothing about the heads. I have built heads I was planning on using on my build.
