edward, you were crossing the stripe in 3rd gear with your 5r55 auto, right?
rpm = (mph x final gear ratio x 336)/tire diameter
rpm = [101 x (3.73*1.55) x 336]/28
rpm = 7000
does that jive with your notes?
4r70 gear ratios are: 1st: 2.84 :1 2nd: 1.55 :1 3rd: 1.00 :1 4th: 0.70 :1 Rev: 2.32 :1
with the new trans, will you cross in 2nd or 3rd gear at the 1/8th stripe? If you cross in 2nd gear, there's no change to the math from above. If you cross in 3rd gear with the new trans, 4.10's would have you crossing at like 5000 rpm...
