It's early and if I'm reading this right you just swapped pin 17 over to pin 21 spot and it works? If you have any more insight or information, can you send me a pm so we don't clog up this thread.
Well, it is good to clarify in this thread.
Answer is YES that is what I did, and yes it is now driving correctly. The reverse lights were still on at all times but it does drive now!
NOTE: On my AUTO tune with my AUTO PCM the thing worked correctly as far as the reverse lights. Only problem we wanted to use a MANUAL tune with my AUTO pcm. This is when the reverse lights would stay on at all times. More of a problem the computer would see me in reverse and limit throttle and torque.
Disclaimer.. not sure if this could damage something in the pcm and disconnect the battery first!
So.. on my 2007 Auto PCM I swapped out the said pins and the car does drive now but the reverse lights were still on. I think the signal to the engine controls was taken out of the loop. If my theory is correct I would bet you could just remove pin 17 and leave it out! Theory that is..
Also, not sure what the differences are between the 05-06 auto pcm and the 07+auto pcm. They "could" be different.
In your case Tungsten, I would try removing the wire first and testing it out. I would hate for there to be a difference in the two pcm's and you possibly fry a pcm. Granted, it is just a signal wire but still...
Now, if this works for you you will still need to go behind the SJB and take those signal wires to the reverse lamps and find a way to make them work. I already have a reverse switch wired in my Hurst shifter.. I did that so I would not have to "hold" the stupid TB button to back up.. you could easily do that too!
Basically this is what I did.. just swapped the pins in this diagram.
Top plug of the PCM is easier to access than the mlps as little room is in the trans tunnel and the harness is short.
The end of the connector is labeled for those pins. The pins in the middle are not labeled as there is not enough room. Just count down from one of the labeled pins to find Pin 17 which will be the LB/BK wire
Here is pin 17 (I would test it first without placing it in pin 21 just to try it)
If that does not work, then you "could" try to place it in pin 21 as I did but at your own risk. Note: my PCM had the actual pin in the PCM but the connector has a plastic block in the way of the pin hole. First remove the red pin lock/guide inside the connector. Next you simply take an awl and poke it out (designed to push thru). Poke it thru the way the wire will go into the new pin location and make sure you remove the plastic piece from the connector. Now you can relocate that wire to pin 21.. again at your own risk. Lol.. my tuner made the joke of "well it could work or catch on fire". At that moment in time I would have been satisfied with either outcome
This pic still has the red pin lock out. Install it before connecting to the pcm, then connect the battery and hopefully your issues are solved.
