Heaten m90
- Joined
- Jun 3, 2017
- Posts
- 335
- Reaction score
- 8
I have to bring this up, i understand the v10 has a split pin crank, but its forged. Why has no one build a nasty turbo v10? They are dirt cheep online.
Did u search the board about your question.......?
Ford built a mule with a 2v v10. It was pretty badass but it never made it to production. Ive seen a few swaps but they were all new edges, no 3v's. Its probably not worth it but it would be pretty cool and unique.
Yes, it didn't yeild anything. Has this been done?
The biggest problem was the 6,8 is longer in the rear than the 4.6 so the firewall/tunnel has to be cutout and modified for it and the tranny to fit.
I don't believe this is true.
That was a one off aluminum block 5.8l V-10 with 4v heads strapped into a new edge chassis. According to the article the ignition system was a bit of a nightmare as they had to use dual ECM's [and dual associated sensors] from the 6.8l to fire the thing due to the odd design of the crank.
It made Coyote like power.
As for installing a 6.8l V-10, It's been done a couple times and there's a thread on another forum detailing one install but I can't find it.
Since there's no intake other than the truck available it was pretty much dead after 5500rpm.
Youre right it was a one off. I forgot it was a 5.8 not a 6.8 though I didnt know it was a 4v. That goes to show you how far technology has come since the start of the 21st century. Its still a cool ride though it'd be cooler if the parts were readily available. A 5.8 v10 under the hood sounds pretty cool lol.
