Hi everyone,
Can you please take a look at my gear pattern photos?
This is a new Richmond gear set in a Ford 8.8 rear axle.
Do the drive and coast patterns look
correct, or do they need adjustment?
If they need adjustment, should I:
My backlash measures between 0.18 and 0.20 mm across six different ring gear teeth.
add or remove pinion shim?
or just adjust the backlash?
Any advice would be greatly appreciated. Thank you!
