AC Only Cold on Passenger Side
Sky Render
Stig's Retarded Cousin
NW of Baltimore, MD
This happen to anyone else? My AC is only blowing cold in the passenger side. I do NOT have dual zone climate control.
Any ideas?
1950StangJump$
I had that happen on a Toyota Venza once. Turned out, it was low Freon. I have no idea why being low caused this to happen, but it did, 100%. I recharged it, and all was well again.
Sky Render
NW of Baltimore, MD
Fuck it; I'm paying someone to do it.
How much of the dash needs to come out? I've got an nGauge in the driver vent and gauges on the pillar. Are they going to be in the way?
07gts197
Naples, Fl
I believe I had to pull both a pillars when taking my dash out to replace the evaporator core. Its a time consuming job but not hard. If you bring it somewhere theyll charge you out the ass for labor. If money is no object have someone else do it.
Sky Render
NW of Baltimore, MD
I'd love to meet the brilliant son of a bitch who thought putting the low pressure service port on the strut tower behind a main wiring harness and above the headers was a good idea. I can't even connect my gauge to the port!
07 Boss
Sin City
Depending on which door actuator needs to be replaced it can be simple or difficult. I think there are four different ones in there.
bujeezus
Alabama
Where is the EMTC located? I've had a few occurrences of the temp control getting stuck and would like to try this.
rathair
I had this same issue on my 07 Accord, I thought it was low on gas, but it turned out to be the evaporator was plugged. Sorry in advance, if this is your issue. It sucks
Sky Render
NW of Baltimore, MD
Have the car checked for hvac codes from the Smart Junction Box. Have you tried the Cold Boot procedure? http://iihs.net/fsm/?d=332&f=Climate Control System.pdf&p=2
Best to make sure it's an actuator problem first before tearing into the dash removal for a broken door.
Well the air that is coming out isn'taas cold as it should be, so I'm thinking low refrigerant or plugged evaporator or condenser. But that's an interesting nteresting idea; where is that module located?
07 Boss
Sin City
I thought it was a side to side distribution issues not a not cold enough issue. That changes everything. You need to go get a set of gauges to diagnose.
357SIG
Arizona
My 2012 had the same issue. Driver side was blowing 15 to 20 degrees warmer than the passenger side. A few shots of Freon corrected it.
Boone
Automotive Enthusiast
High Point, NC
If your car is equipped with dual climate zones, the drivers side will blow cold and the passenger side warm with low freon. Happend in my 06 Explorer. AC also shuts the compressor of briefly with a misfire code.
Sent from my SM-G950U using Tapatalk
