F&S Stangs
Did a search and have been reading the posts for the last hour or so.
If I understand correctly, there should be no gear whine under any conditions if the install was done properly. Is that correct?
This is the problem I'm having. The whine is most noticeable during decelerate between 40-50 mph, none below 30 mph and I can hear it during up-shifts above 60 mph. The gears are Ford racing 373N gears not the Motive gears. The gears have about 350 miles on them. 2 heat cycles done (one by the shop) both around 25 miles. Saturday I went on a little trip about 110 miles one way with several hours of cool down time in between.
Am I being too picky here, or is there a problem?
Backlasch too loose or tight?
