blownGTvert
**SOLD** Aeromotive Eliminator in tank fuel pump #18677 pump is design for a return style fuel system. This is the last pump you will buy! It's a beast rated at 875 lph. Only draws 30a (compared that to a triple pump system @ 90a). Features a billet hat, uses OEM fuel sender (included) and OEM connector. Original instructions are included.
Aeromotive pump controller # 16306 for above. Used to run the pump in low speed while not in boost. Can be triggered by tach signal, Hobbs switch (included) or both. Features a billet case with pulse width modulation (just like the OEM pump driver module). Original instructions are included.
The 30a fuse, Hobbs switch and all wiring is included with the pump controller. None of the wiring has been cut or spliced! Plug and play for a super easy install. If you want the best pump and fuel system for the 05-10 S197 this is your chance.
