AFR : Tune or something else
Enitalp
The lost guy.
Canada, QC
I just installed an AFR Gauge on my NA Mustang.
At idle i have a reading from 14 to 17/18, it's not stable at all.
When i drive it's around 14 to 17. If i go woot it jump to 12 then go back to 14 immediatly after. and then still move from 14-16 randomly.
In resume it not stable at all, and i have an average of 16.
Tune is from bamachip.
I have a bosch sensor. plugged on the driver side at the end of my OffRoad long tube header.
Been to the track, car was totally consistant at 12.80/12.90 (in 10 runs). Even if i found that very slow. was waiting more 12.40.
Any idea. (i know nobody with a AFR to double check mine) ?
Thx
Dex
I'm Dexolishous
Utah
Idling anywhere from 13-17 is normal.
So if you go WOT and stay in it the AFR stays at 12 or does it go to 12 then up to 14?
Enitalp
The lost guy.
Canada, QC
it stay at 12 a very little (less than 1/10th of a second) then go back to 16/17
I will have to try to make a video. as i have a plot mode we can check the history.
Dex
I'm Dexolishous
Utah
if you go WOT and rise above 13.5 then you are way too lean.
shawn13
Dwight,Illinois
I would order a new tune(vmptuning.com). When you go wide open your A/F should be at 12.5 and stay at that till you let off the gas.
My idle A/F runs 14.5 to 14.8 never any higher.Did you try pulling your 02 sensor make sure its clean and recalibrate your wide band ?
08gt4u
you might want to get it on a dyno to make sure is reading correct.
Enitalp
The lost guy.
Canada, QC
My AFR is without calibration and doesn't stay at all at 12, and it must be clean it's brand new.
A dyno in montreal hahahaha. :thud:
That's our main problem, no one is able to do real thing on a mustang there.
Last time i was on a local dyno they gave me a 338 RWHP (i'm NA with stock long block). They only do civic in the week end.
shawn13
Dwight,Illinois
Before you installed the wide band 02 sensor you need to do a fresh air calibration. then after a while you need to remove the 02 sensor and recalibrate it.
