Aluminum Flywheel with a PD Blower
sdleo29
Any downside to having an aluminum flywheel versus steel with a PD Blower? I was told it was no good because of rotating mass difference etc etc .. I assumed perhaps there was logic there as a PD blower has instant torque:revs versus a centri ... What's the bottom line?? Thoughts
Tranny is out of car and now would be the time to change if there is s downside.
Thanks all
skwerl
tree hugger
central Florida
IMO it will be way too twitchy on the throttle. I had a lightened steel flywheel on mine and throttle changes were super quick. You also need the mass to help carry rpms through the gear changes.
My Shelby has a alum flywheel in it.
depends on how you're using the car general wisdom says: racing = alum fly, mostly street = steel
I've never found an issue with street with mine
loots06
Monterey CA
I removed mine in my recent build and went back to stock, but I'll be going back soon.
Department Of Boost
Alpha Geek
I've never had even the smallest issue. I think a lot of it has to do with how I let the clutch out though. I give the throttle the smallest blip and when the RPM's are on the wat back down I start to let the clutch out. A bit of a brap, braaaaaaaaaaaap. The blip is really small and only a split second.
I think I got this from motorcycles.
travelers
Eastern Pa
I do the same with both the car and the H-Ds. Mine came from 18wheelers I think
drive_55_not
I've ran numerous clutches that weighed from 56lbs to the lightest at 34lbs. Stock clutch/FW weighed 48lbs IIRC.
My current ACT twin disc weighs 42lbs and is about perfect.
Daily driving is a little better with a heavier clutch, especially in traffic as you don't need to goose the throttle as much to get moving. Gas mileage will suffer with a heavier clutch.
The 34lb clutch was a bit of a bitch in traffic, takes more throttle to get moving, if you have a loud exhaust people will think you're wanting to race coming off a stop light ... and the engine will slow down much quicker coming off the gas. My gas mileage improved by 3+mpg wit the light clutch over a nominal weight clutch.
As far as drag times, I saw minimal improvement with the light clutch compared to the 55lb'er. The light clutch did help with high rpm power-shifting but you still gotta blip the throttle to power-shift a synchronized tranny and a light weight clutch will really porpoise on those shifts.
