Aluminum Tank Identification
Scott
King City, Ontario, Canada
Remembering I had hip replacement surgery late last month and I am not approved for a romp in the garage yet working on the car; I am trying to determine if I can fit the 11955 4 gallon tank in the rear tire well. If this first picture is the 11955 tank then it should work?
Not sure where I found this picture, but I was hoping to confirm this tank is part number 11955, 4 Gallon 30” L x 6” H x 7.5” H?
This picture is from (GallopingFord) Cam’s thread and I know this tank is part number 11958, 2.5 Gallon 20”L x 6” H x 7.5” H.
Lansing,MI
Yes those are the correct measurements for the 11955, honestly I have never tried to install one in the spare tire well. If anything the tank may be a little too tall and you may need to build a false floor to cover everything.
Take it easy on that hip!
retfr8flyr
The Old One
Providence Forge, VA
I read somewhere that you guys are working on an auto controller for the digital setup. Is this true and if so do you have any time frame for when it will be available.
Earl
Lansing,MI
Earl
Hey Earl, by auto controller do you mean auto leveling or the remote set up?
Scott
Pulled the carpet up yesterday and Cam was right, clearly the 11955 tank (4 Gallon 30” L x 6” H x 7.5” H) does not fit length wise or width wise in the tire well (no issue with depth of the tank).
The port/hose configuration in the first picture below certainly looks like the 11955 tank but it can not be one. Looks like I need a 11958 tank if I am going to install it in the tire well.
Wes06
how about the bluetooth dongle for phone/tablet control? :D
