Any Nitrous guys tried these before?
waldogt07
Pelham, Alabama
I went with the Plate kit here.....A little bit cleaner looking under the hood.....but I am sure there is someone that has used them here
ngnichols
Dallas, Texas
I installed NOS' brand of this type of system a while back and it worked, but you'd be better suited with the single-nozzle or plate system. I believe there were some puddling issues with these injector systems.
Full_Tilt
Theyre terrible.
1) They negatively effect the spray patter of the fuel injectors
2) The do not flow nitrous well (i.e. uneven, inconsistent, and poorly atomized shot.
3) Youre injecting nitrous as just about the worst possible place in the runner
You just suck it up and drill and tap your manifold in the right place and use a real nozzle.
I know it sucks but its not like its irreversible. You can plug the holes with little alen set screws if you ever remove the nitrous setup.
