Brezick
Yinzer
- Joined
- Jul 14, 2011
- Posts
- 1,386
- Reaction score
- 0
What headers did he use?
He took the flanges from a 3v and had them welded to a set of pypes 2v LT headers.
I did a 4V Mach1 swap on my old red coupe with all new edge wiring mach460 one-touch power windows remote keyless entry etc. several years ago.
It was a nice little car. The last owner put a Terminator motor in it.
It's a easy swap
You can use a stock sn95/new edge k-member and 1" shorter than fox length a-arms to keep stock track width using 96-04 spindles.
Use a frpp control pack for the 3V or a Fast or BS3 or Pro-efi with cam phaser lockouts.
A 01-04 style 3650 or t56 will work
99-04 hydraboost just swap the new edge brake pedal into fox pedal box.
Use 99-04 p/s hoses.
96-04 a/c compressor with matching a/c hoses just swap evaporator over to 96-04 outlets(easy swedge and solder)
Couple of questions SSP:
If a complete 05-09 pull out is purchased (3V motor, 3650 trans, and wiring harness) or a complete S197, can the 3650 and wiring harness be used? Most of the swaps I've found say to used the FRPP control pack. Also you mentioned using a 01-04 trans, why?
With using the newer k-member, which steering rack do you use? Fox or SN95?
My goals are to have a stock manual 3V with power steering and A/C. Once everything is installed and running flawlessly, I will start modding.
Thanks for any info.
Looking thru the UPR website, the modular tubular K is only $100 more than 1" shorter fox arms. I'll probably use a UPR K-member with factory arms. Would there be an issue installing the hydroboost and stock 4-lug brakes? I want to maintain the sleeper/4 lug look.
You built this motor?I did a 4V Mach1 swap on my old red coupe with all new edge wiring mach460 one-touch power windows remote keyless entry etc. several years ago.
It's a easy swap
Although if I had to do a mod swap again I would go coyote like my buddy did this Saleen that I built a motor for
Man you ever came out to the meet in spring? I would love to meet you in person.
No I don't get to many meets just some track events. I got 5 kids at home and several cars I am building for myself and my wife and some friends.
That Fox makes great power it won't hook for nothing on the street. It's a forged built coyote with stage3 cams. It will likely be twin turbo by this time next year.
I built the motor and my buddy Bobby finished the car. The owner is a buddy of ours Parker.
He puked his SBF 306 all over Chris' Dyno before swapping to a Coyote.
I will be at Tx2k hopefully as well as Parker and Bobby(black Mamba TT coyote Mark VIII )
My little brother goes to the Spring meets sometimes he has a Pi swapped 96 GTS that I built
There's a guy on Instagram I follow, @3vfox (go figure right) who swapped in a 3v with a lil paxton. From the videos he posts, the thing absolutely rips.
