Anyone having issues with thei TCI Shifter?
Hysteria
0 .· ` ' / ·. 30 psi
Tampa, Fl
If I'm sitting still and just running throught the gears, it firmly stops at each gear and locks out of Nuetral.
If I manually shift the car at WOT, the shifter goes into Nuetral no matter what gear I'm in. So if I start off in 2nd on a roll, and nail it, once I shift, the shifter goes into Nuetral, bypassing the gates.
Doesn't make any sense.
Anyone else had this issue?
whyask
NORCAL
WOW that blows.. I have a TCI and nothing at all ... did you check the cable under neath the ride and double check to make sure the electronic hook up didnt shimmy loose ..??? (i know that, that is next to impossible but with these cars you never know)
Hysteria
Tampa, Fl
I'll get my shop to check it out.
It doesn't make sense that a shifted would lose its gates under WOT.
